Well my previous post was done quickly, right before I had to leave for work.
I done some thinking, and went back to VS9 to see if it might be a problem with the video clip itself.
I opened VS9 and imported the same clips to create a DVD. In VS9 I could place the chapter points where I needed them. However MF4 for some unknown reason will not.
Properties:
FILE:
File Format: NTSC DVD
File Size: 660,042KB
Duration: 906.540secs
VIDEO:
Video Type: MPEG-2 Video,Lower Field First
Total Frames: 27,169 Frame(s)
Attributes: 24 bits, 720 x 480, 4:3
Frame rate: 29.970 Frames/Sec
Data rate: Variable bit rate (Max.6000kps)
AUDIO;
Audio type: MPEG Audio Layer 2 Files
Total samples: 43,513,914 Samples
Attributes: 48000Hz, 16 Bit Stereo
Layer: 2
Bite Rate: 224 kbps
I want to create only 3 chapter points in this video clip. I have a total of 7 video clips for the DVD. Some of the clips have more and less then 3 chapter points. I don't believe that all clips have to have the same number of chapter points.
I do want a motion "main" menu background, and would like it for all my menus, however don't have a motion menu for a couple of the clips. So have used a static background image. Would this be a confilct that would mess up chapter points?
I have menu background music, most being the same.
I do have a couple of different file formats (if the VBR constitutes a different format), however all were rendered to MPEG NTSC DVD.
So any ideas on why MF4 DC will change the frame(s) where I manually selected chapter points?
Thanks again
