OnOne Perfect Effects
zombielord
motherboard: ASUSTeK COMPUTER INC. Z87-K
processor: Intel Core i7 4770K [3.5Ghz 4.1Ghz OC]
ram: 32GB DDR3
Video Card: NVIDIA GeForce GTX 770 2GB
Hard_Drive_Capacity: 8 TB
Monitor/Display Make & Model: ASUS Pro Art PA248, ViewSonic VP2785-4K
Corel programs: PsP2018, VSx10, Painter 2018, AS3 Pro
Post by zombielord »
http://forum.corel.com/EN/viewtopic.php?f=56&t=57284
Posting here to see if we can't crowd source a better script.
NOTE: Script based on Nik Color Efex Script
Download link >>> https://www.dropbox.com/s/8qphrirebr98w ... cript?dl=0 <<<
Painter 2018, Paintshop Pro 2018 Ultimate, Aftershot 3, VIdeo Studio x7, WinDVD Pro 11, PhotoMirage
>>> http://joshuameadowsphotography.com <<<
motherboard: Alienware M17xR4
ram: 6 GB
Hard_Drive_Capacity: 500GB
Corel programs: PSP: 8-2023
Re: OnOne Perfect Effects
Post by LeviFiction »
The only way to fix the first one is to know what the copy file name is. Or using the open command set to the same path so the user can select which file they want.
The JPG issue might be solved by changing the SaveAs parameter for 'EmbdJPGICC'. It's currently set to False. Have you tried setting it to True? It might force Perfect Effects to use sRGB when saving out the file. Then PSP won't complain.
zombielord
ram: 32GB DDR3
LeviFiction wrote:The only way to fix the first one is to know what the copy file name is. Or using the open command set to the same path so the user can select which file they want.
Thanks that fixed the JPG issue.
I added a message box telling the script user to edit the original file as the script already makes a copy and I can't find where OnOne make's its copy of a copy.
I still can't iron out what the issue is with TIF files (as that is the file format I prefer). On further research if I use a JPG or TIFF as the original file OnOne returns a nicely formated file.
If the file is converted from a RAW file then after OnOne processes the file the returned file is jumbled. I'm still doing research to fix this issue.
gbotes
Hard_Drive_Capacity: 500Gb
Corel programs: Paint Shop Pro X8, Aftershot 2
Post by gbotes »
I tried this script on Windows 7 64-bit with PSP X8 64-bit, but I just find that PSP crashes when I save and close in Perfect Effects - zero successes out of three attempts in my case. i don't suppose there's any chance Corel will just add support for .8li plugins?
zombielord
ram: 32GB DDR3
Sorry haven't used the script in a bit for some reason loading the modified image as a new layer works with one PSP update and then not the next (I had this same issue in x7).
I had a backup solution already in the script where it opens as a new image. I'm going to upload the script to where it does both again to where at least one works.
You can either remove the comments symbols from the section of code or re-download the script.
justncase007
motherboard: EVGA 780i
processor: intel core 2 Q9650
ram: 4gb
Video Card: Raedon 6950
sound_card: none fiber amp
Hard_Drive_Capacity: 1500 GB
Monitor/Display Make & Model: Gateway LP2424
Corel programs: paint pro x8
Post by justncase007 »
I have perfect effects 8.0 can anybody make me a script to work with 8.0 or can some nice person give me the free Perfect effects 9.5 i didn't get that in my propaint x8 Thanks I guess its alright to post that anfer all its free,yo
