So i couldn't find a forum of its own so will post here and then a MOD can move if appropriate .
If corel Screencap X8 has "System audio" enabled in settings it will fail , If i disable that option it works fine . Now why is this ?
Is it some weak attempt to stop the software being used for piracy ?
I am running windows 8.1 with all updates up to date .
Just use this for doing my youtube videos but now it wont work so am using something else .
Solution please >
Corel Screencap X8
Re: Corel Screencap X8
The inference I get from your post is that it did work but now it doesn't - is that correct - so what changed - was it maybe a windows update that created the problem
you may want to check for new drivers for your audio system - if it was caused by a windows update your drivers may need updating.
dan44762000
I am not sure what has changed regarding windows updates but i always install them , And my audio drivers are always up to date.
It captures the screen and my voice but if i enable "system audio" i get the error .
prepare video failed!!! #01
No other issues with any other program on my pc , its just screen cap X8
pyrod
- motherboard: Gigabyte GA X79 UD5
- processor: Intel i7
- Video Card: Nvidia 9800GT
- sound_card: M-Audion Revolution 5.1
- Hard_Drive_Capacity: 1.5TB
- Monitor/Display Make & Model: Samsung
- Corel programs: X5 X6 X7
I am using Video studio X7 and had the same problem. I thought it was because i am using an M-Audio sound card but that's not the case, I tried a few settings and nothing changed until i set the sound card to Stereo output not 5.1 surround as my default speaker output was. Now i can capture the screen with system sound.Hope it can help someone.
Best of Luck to all
Best of Luck to all
