Using "One Step Noise Removal" applies a colour cast
John-S
motherboard: Gigabyte Technology H67A-UD3H-B3
processor: 3.40 gigahertz Intel Core i7-2600
ram: 8 GB
Video Card: NVIDIA GeForce GTX 650
Hard_Drive_Capacity: 8370 GB
Monitor/Display Make & Model: DELL U2713H
Corel programs: PaintShop Pro X7
Post by John-S »
Applying "One Step Noise Removal" applies a colour cast to the entire image. I am running X7 at the moment but the same problem was present in my previous version which was X4, when I had the same computer but a different monitor.
To best demonstrate the problem, create a small new file and fill it with a mid-grey (128, 128, 128) and then apply the One Step Noise Removal. A slight shift towards red should be evident. If the noise removal is applied several times the effect is additive and becomes more and more obvious. The attached file shows the result of applying the noise reduction 10 times to the mid-grey square.
Is this a known problem, and if so, is there a workaround or a way to prevent it happening?
Thanks for your help.
John-S.
One Step Noise Removal x 10.jpg (2.02 KiB) Viewed 2208 times
Jean-Luc
Hard_Drive_Capacity: 2 Tb
Re: Using "One Step Noise Removal" applies a colour cast
Post by Jean-Luc »
Good catch !
It is a bug.
What happens is :
at each tool application, R and B values are increasing 1 unit (approx.) and G value is decreasing one unit.
R128 G128 B128 becomes R129 G127 B129
On next application (same image), the values are R130 G126 B130
I'll report it to Corel.
John-S
ram: 8 GB
Post by John-S »
Thanks Jean-Luc.
Do you know if it's likely that there will be a bug-fix release for X7 or would that type of thing have to wait until X8?
John-S.
Jean-Luc
Post by Jean-Luc »
John-S wrote:Thanks Jean-Luc.
John-S.
Hi John-S,
I'm not working for Corel...
:D
But I think there will not be a new Service Pack for PSP X7.
As it is a very old bug (exists on previous versions too), it means no one observed the defect before. Or, in other words, not many users have problem with this defect. If Corel corrects the problem, they will not gain users. They calculate how many money it costs to correct a bug and how many NEW users they will have after the correction. In the actual case, I think not many new users. And they will not lose users too.
But perhaps the bug is easy to correct and could be corrected in a future version. Who knows ?
