Frame issue on VideoStudio X8
stathis80
motherboard: GIGABYTE 990FXA-UD3
processor: AMD Phenom II X6 1090T
ram: 16gb
Video Card: NVIDIA GeForce GTX 560 Ti
sound_card: SoundBlaster Audigy 2 Platinum Ex Retail
Hard_Drive_Capacity: 300gb
Monitor/Display Make & Model: LG 27inches
Corel programs: Corel VideoStudio X5
Post by stathis80 »
Hello, I have an issue with a frame on VideoStudio X8.
So, i was doing my projects on VideoStudio X5 and in the end of my video, i was using this frame here:
When I bought the VideoStudio X8 and I wanted to use the same frame, its colours changed and became like this:
I didn't do anything, i just inserted the old frame from X5 to X8.
Why is this happening? Is there a way to fix it? I want to use the frame like it was in X5 to VideoStudio X8 !!
Please somebody help!
Re: Frame issue on VideoStudio X8
Welcome to the forums! :lol: And don't worry -- your frame is in fact white or as in the second image!! :roll: It's just the way you have your timeline set up. That greenish colour is just the default colour of all the timelines. If you look to the immediate left of the green you will see a frame showing what is in the preview screen.
If you want the green to go and be replaced solely by frames showing that same image then go to Settings > Preferences > Clip Display Mode and select Thumbnail Only. The green will now be replaced by a series of individual frames for the length of that particular clip.
asik1
motherboard: H170M-E D3
processor: i5-6600
ram: 8gb
Video Card: GTX1050-2GB
Post by asik1 »
Ken, you totally didn't understand the poor guy problem. It's not a time line thing its the png .
Stat, what you are using is a png file with transparency. this kind of files are ment to be on the overlay track.
The black here represent transparency, if you want to have a white instead of black in your project, put a white clip on the first track and the png file right above it on the overlay track.
Panasonic X900m, VXF1
Post by BrianCee »
So is the basic problem that it shows a light grey in X5 but as bright white in X8 - I would think that's just because of the way Videostudio displays the frames
if that is your problem then why not just export the png you moved between versions to an image editor - change the colour - and put the resultant image back into X8 - in fact the way you appear to be using it you do not even need a frame with transparency so a standard jpg would also work
skier-hughes
Microsoft MVP
motherboard: gigabyte
ram: 4GB
sound_card: onboard
Hard_Drive_Capacity: 36GB 2TB
Post by skier-hughes »
To me it looks like the frame has changed from a full one to one with a wavy bit at the bottom. It may have the same name, but it is a different item.
stathis80
ram: 16gb
Post by stathis80 »
asik1 wrote: put a white clip on the first track and the png file right above it on the overlay track.
omg! that worked! It worked! I can't believe it! :D Thank you very much!
But i find it a little bit weird why I had to do such thing in X8...
I mean, shouldn't it work right away with the correct colours? But anyway....since it worked....I am ok with it...
Post by BrianCee »
You could also use any other colour or a still photo or a patterned image in that situation
