I've had problems with Corel VideoStudio Pro 7 in the past and abandoned it; don't recall what but some type of crash. Questions:
1. Are there some file types that Corel VideoStudio Pro is more friendly with?
2. Are there settings in Corel VideoStudio Pro that are more apt to insure fewer crashes or other problems?
3. Are their limits one should not cross. For instance, I recently imported a hundred very short, mostly less than a minute, clips and when I tried to delete them, Corel VideoStudio Pro 7 crashed.
Problem signature:
Problem Event Name: APPCRASH
Application Name: vstudio.exe
Application Version: 17.1.0.22
Application Timestamp: 538721fe
Fault Module Name: mfc110.dll
Fault Module Version: 11.0.60610.1
Fault Module Timestamp: 51b4fccb
Exception Code: c0000005
Exception Offset: 0000000000001a61
OS Version: 6.1.7601.2.1.0.768.3
Locale ID: 1033
Additional Information 1: 6a4b
Additional Information 2: 6a4bffa2c2c7cfbfcba62879c07aa344
Additional Information 3: 4e83
Additional Information 4: 4e8329bee3437d3b5ca1f432d88d994c
Corel VideoStudio Pro then generated a "Load from stream error" message and this message could not be terminated but looped infinitely. Even ctrl-alt-del task manger could not kill it. So I rebooted and tried again. Same error. Now Corel VideoStudio Pro will not start at all.
Had to delete the folder as described here http://howto.corel.com/en/c/Load_from_s ... Studio_Pro in order to get the program to start again.
Stability Crash Performance Advice. How to avoid problems?
