Removed folder from collections. How to get it back
nanrector
processor: Intel Core i7-8700 CPU 3.2GHz 6 Core
ram: 32 GB
Video Card: NVIDIA GeForce GTX 1070
Hard_Drive_Capacity: 10 TB
Corel programs: PSP 2019 Ultimate
Post by nanrector »
Hello!
I accidentally removed a folder from my collections. It was nested in another folder. How do I get it to show again? I've tried reading the whole upper level folder again but it still skips that folder.
Thanks!
Nancy
PSP X4
Windows 7
Nancy Ü
PSP X4
MarkZ
ram: 8 GB
Hard_Drive_Capacity: 500 GB
Re: Removed folder from collections. How to get it back
Post by MarkZ »
In Manage/Collections/Folders click on "Browse more folders". In the window that opens, follow the tree to the folder you want and select it. It sounds from what you write that you deleted a sub-folder; in that case if you just select the folder containing the sub, you will not get the sub-folder you want and if you select the sub-folder only it will appear on its own, not as a sub. So, the solution is to delete the folder containing the sub, then re-install it in Collections. I hope this isn't too confusing - tried it and it works.
Mark
nanrector
ram: 32 GB
Post by nanrector »
Thank you Mark! Could you tell me where I "manage" the collections? I don't see a menu item for that.
Nancy Ü
PSP X4
Kathy_9
Hard_Drive_Capacity: 2TB
Post by Kathy_9 »
I don't use Manage but I think what Mark is saying is that on the Manage Tab you should click on Collections and then Browse More Folders.
click for larger view
nanrector
ram: 32 GB
Post by nanrector »
I deleted it and added the entire root folder back in. My sub is back again now. Thanks SO much!
Nancy Ü
PSP X4
