Auto Music not playing during playback
willyto1
operating_system: Windows 8.1
Post by willyto1 »
Hello,
I have an 8 minute video into which I have added auto music. When I attempt to play the entire project from start, I see all video and titles, as well as hear voiceovers. However, I don't hear the Auto Music.
It is not disabled and the volume is 100%.
Any help is appreciated.
Willy
Re: Auto Music not playing during playback
Post by BrianCee »
Hello
Since you have not told us which version you are using I am having to guess that your using X8 in which the automusic is a bit different from previous versions.
When you use the automusic in X8 the first time you try to play a project with it in you will see a message to the effect that a rendering process is in process (and that you can press esc to by pass it) - unless you let that rendering process complete - and it is best not to press esc as that seems to delay it - have you allowed that process to complete.
as a secondary check - when you select the music block in the timeline and play 'clip' can you hear anything then.
willyto1
Post by willyto1 »
Apologies, using X8.
And I figured out the issue. When previewing a track in Auto Music, it plays just fine. But when added to the 'music track' it does not play at all. Just a few of the music pieces have this issue. Most of them play just fine when added to the 'music track'.
