I hve just install ULEAD video studio 9 an a 30day trial. It seems to be working fine. However I have noticed that Windows Media Player has stopped playin AVI files. The video seems to work, but is perhaps a bit choppy. The sound no longer works at all. AVI works fine in Video Studio.
Has Ulead installed a different codec, if so how can I get both programs tp play AVI.
Thanks.
Lost audio using MS Media Player
You could be right. But the only time I had trouble playing my video clips on WMP, I was advised to download the Windows XP Video Decoder Checkup Utility at http://www.microsoft.com/downloads/deta ... laylang=en
This checks to see if you have the correct or up to date codecs. I found that one of mine was not correct, but curiously, the utility told me that the correct one was from neither Windows nor Ulead, but was a Cyberlink Power Director one. Once I updated, my WMP problem went away.
grahamGollings
Thanks for the pointers. Since posting my question I ugraded from WMP 9 to 10, but the problem is the same. Running Ulead video studio and right clicking-properties it says the following. File format Microsoft AVI, frame rate 15.009 frames/sec, data rate 253.18 kbps, video MJPEG compressor, Audio IMA ADPCM attrib 11.025k/z 4 bit mono. Does that tell anyone anything?
I opened the same AVI file in WMP, under File-Properties it gives media type video,audio codec - dash,video codec - dash. So WMP doesn't seem to be using a codec at all?
Apple Quicktime plays the AVI fine.
I downloaded the windows media checkup utility. It appears that I have only 1x MPEG-2 compatible decoder which is Cyberlink CLVSD.ax v6. All the other decoders are said to be imcompatible with the WMP synchronisation feature (whatever that is) including Ulead decoder 2 UlDVDVideo.ax v2 and Ulead MPEG decoder uldsmpeg.ax
Now I am lost - what to do next ??
