Video length incorrect and have to play from the beginning?
LinsnowX
- Hard_Drive_Capacity: 12 gb
Hey guys I ran into this weird problem that I never had before. I edited my film using .mov footage then render them into an .mts file. However, this is a 3.5 min video but the file property says 9.5 min. Also I can play the video from beginning and it's OK, but when I try to play it say, from 1:00, it will freeze. I tried render the same project into .mp4 and that works without any problem. I also upgraded from X7 to X8 but the same problem is still haunting me. It's really annoying... any idea how to fix this? Thanks!
asik1
- motherboard: H170M-E D3
- processor: i5-6600
- ram: 8gb
- Video Card: GTX1050-2GB
Re: Video length incorrect and have to play from the beginni
As you know it's all in the "video settings" .
So check again your videos properties and at what settings you renders.
Panasonic X900m, VXF1
LinsnowX
i used the 4k 30p 40mbps preset, i also tried a 4k 30p 65mbps custom setting, both result in the same problem so i don't know what i can do about it...asik1 wrote:As you know it's all in the "video settings" .
also seems like videostudio has a problem with .mov files too but that's the only practical file type i can use from davinci
asik1
- ram: 8gb
.mov files on PC are pain. So you better fight your QuickTime than VS.
I think Corel will be flattered to know that you marriage davinci with VS.
LinsnowX
yea i'm kinda in a dilemma now. very familiar with corel, digged into davinci a little bit and now this two just won't work together... probably will be forced to use premier proasik1 wrote:.mov files on PC are pain. So you better fight your QuickTime than VS.
