Playback "Clip" is nice, playback "Project" is horrible
Peter Sarek
operating_system: Windows 8.1
motherboard: Dell Inspiron 2350 Touch
processor: Intel i7
ram: 12GB
Monitor/Display Make & Model: Dell Inspiron 2350 Touch
Corel programs: Videostudio X8 Trial
Post by Peter Sarek »
Hi All. I have installed Corel VideoStudio Pro X8 Trial. I'm not an absolute novice in video editing, I edited my home videos on Apple iMac for several years. VideoStudio is very nice application, but I have a big problem with it. When I switch to "Clip", playback is fine, after switching to "Project" playback is jerky and pixelated. I used the sample clip installed with application and made a very short video. After I rendered it, the final video was jerky and pixelated too. So VideoStudio Pro X8 has a problem even with it's own sample clip! What am I doing wrong? Thanks in advance. Peter
canuck
Re: Playback "Clip" is nice, playback "Project" is horrible
Post by canuck »
First of all, the "trial" version has many features/options missing or crippled and that may affect the results.
Since you have given no information on exactly what you are doing (what input, what output settings, etc) it is impossible to tell what you are doing wrong. I doubt very much that it is a problem with X8 Pro
Post by BrianCee »
it is very important that your project and output properties match the original clip - can you please provide clip properties - project properties and output file settings.
Peter Sarek
processor: Intel i7
ram: 12GB
Thank You canuck for Your reply. My first testing step by step:
1) I run VideoStudio application
2) Then I drag and drop first sample clip to timeline
3) Press "Play" button - playback is fine
4) I switch playback mode to "Project", playback is pixelated and jerky
5) Rendering give the same pixelated clip
No settings, only this simple test. With source clip from my camcorder same result.
I'm sorry for my bad English.
Post by BrianCee »
BrianCee wrote:it is very important that your project and output properties match the original clip - can you please provide clip properties - project properties and output file settings.
you must match all properties
Peter Sarek
processor: Intel i7
ram: 12GB
Thank You BrianCee for Your reply. When I placed clip on the timeline, playback was fine in the "Clip" mode and very bad in the "Project" mode. It's not actually problem of rendering of final video.
Peter Sarek
processor: Intel i7
ram: 12GB
You can view clip from VideoStudio here:
http://uloz.to/live/xFubZLZa/test-mp4
Post by BrianCee »
Possibly because your project properties are not the same as the video properties
What are the clip properties -- what are the project properties.
When you play in 'Clip' mode VideoStudio uses the clip properties
When you play in 'Project' mode VideoStudio uses the project properties
Peter Sarek
processor: Intel i7
ram: 12GB
Thank You BrianCee :)
Clip properties (video):
MPEG-4
H.264 High Profile Video
24 bits, 1920 x 1080, 16:9
25 frames/sec
Data rate 15000 Kbps
Project properties (video):
Microsoft AVI files
25 frames /sec
Upper Field First
More or other settings is not available in trial version. :(
canuck
Post by canuck »
Peter Sarek wrote:You can view clip from VideoStudio here:
The properties of this clip are completely different from the project properties you posted. You said other properties are not available in the trial version so how did you get these properties of the VS rendered video?
Peter Sarek
processor: Intel i7
ram: 12GB
Settings -> Project Properties -> (select) -> OK
I tried New -> General ... but there are only few options available.
I assumed that default settings and sample clip in trial version are compatible. :|
Peter Sarek
processor: Intel i7
ram: 12GB
OK, can you help me please with project settings for sample clip:
Properties of Corel sample clip:
MPEG-4
25 frames/sec
I'll try to set it and make second test. Thank You very much.
Peter Sarek
processor: Intel i7
ram: 12GB
My DELL computer had probably problem only with Corel Videostudio. I installed SONY Movie Studio Platinum and all works fine. Rendered movie have perfect quality. Studio from SONY automatically detect and setup project properties from source clip. Playback is smooth, as well as the final video.
Peter
