I'm trying to load more than 1 filter in a plugin but no matter what I do Aftershot pro 2 coredump.
The only working example I know of is the Mix v3 by Ferdinand Paris.
The reason I want do this is to be able to fix the Sharpen plugin by Spoilerhead.
Theis is the output from Aftershort
Registering AfterShot plugin... "BibbleBuiltin"
Registering AfterShot plugin... "Equalizer"
Registering AfterShot plugin... "BlackAndWhite"
Registering AfterShot plugin... "MySharpen"
"MySharpen" : "LlorensFilter" : Successfully loaded.
Fatal: Filter name collision
Aborted (core dumped)
This is the code running in registerFilters():
bool MySharpenPlugin::registerFilters()
bool bSuccess = true;
LlorensFilter *pLlorensFilter = new LlorensFilter(m_hub, m_groupId);
if (pLlorensFilter != NULL && !m_hub->addFilter(pLlorensFilter, PluginHub::Tail, QString())) {
qDebug() << this->name() << ": " << pLlorensFilter->name() << ": Failed to load.";
bSuccess = false;
} else
qDebug() << this->name() << ": " << pLlorensFilter->name() << ": Successfully loaded.";
USMFilter *pUSMFilter = new USMFilter(m_hub, m_groupId);
if (pUSMFilter != NULL && !m_hub->addFilter(pUSMFilter, PluginHub::After, QString(pLlorensFilter->name()))) {
qDebug() << this->name() << ": " << pUSMFilter->name() << ": Failed to load.";
bSuccess = false;
} else
qDebug() << this->name() << ": " << pUSMFilter->name() << ": Successfully loaded.";
WaveletFilter *pWaveletFilter = new WaveletFilter(m_hub, m_groupId);
if (pWaveletFilter != NULL && !m_hub->addFilter(pWaveletFilter, PluginHub::Before, QString("RgbToLab"))) {
qDebug() << this->name() << ": " << pWaveletFilter->name() << ": Failed to load.";
bSuccess = false;
if (bSuccess == true) {
qDebug() << this->name() << ": All filters loaded successfully";
} else {
if (pLlorensFilter != NULL)
delete pLlorensFilter;
if (pUSMFilter != NULL)
delete pUSMFilter;
/* if (pWaveletFilter != NULL)
delete pWaveletFilter;
return bSuccess;
Any idea of what I'm doing wrong?
Multiple filters in plugin
Hansi
- motherboard: Gigabyte Gaming 7 Z97
- processor: i4790
- ram: 32GB
- Video Card: Asus Nvidia GTX 970
- Hard_Drive_Capacity: 8TB
- Monitor/Display Make & Model: Dell U2410, HP 25", Samsung 28" 4K
- Corel programs: Aftershot Pro 2
Hansi
- processor: i4790
- ram: 32GB
Re: Multiple filters in plugin
Solved myself...
There must be something in AfterShot called USMFilter so when I changed from USMFilter to AbbasFilter the filter was loaded.
It would be nice with a reserved words list
Now I just have to figure out how big a change it will bring to Spoilerheads plugin...
