Hi there,
I have an issue that I can not seem to figure out over the last couple of months, can anyone help?
I can not import any more videos into my library (Corel videostudio X6) to finish my video. The video is only at 15mins. I have 8Gb of ram on my laptop and about 50Gb of hard drive space left.
I get a message similar to "the programme has encountered an unspecified problem and will close"
If I delete a video it will let me import another video into the library. Does the library have a Gb limit??
Has anyone else had this issue?
Ben
Wont Let Me Import More Videos Into Library X6
beno171717
- motherboard: Apple
- processor: Apple
- ram: 8Gb
- Video Card: Apple
- sound_card: Apple
- Hard_Drive_Capacity: London
- Monitor/Display Make & Model: Apple
- Corel programs: X9 Ultimate
Re: Wont Let Me Import More Videos Into Library X6
I am not aware of any size limit on the library - in any case the library you see in VideoStudio just contains small links - each thumbnail in there is just a link to your actual video file and only takes up a few bytes of your system - the actual files are somewhere on your hard drive - not actually 'IN' VideoStudio.
How many thumbnails do you have in your library - there may be a limit to how many thumbnails can be shown
have you tried creating an additional library and putting your videos in there - does VideoStudio allow you to do that.
have you tried inserting the videos direct to the time line - it is not necessary to actually use a library - right click on a blank space in the timeline and choose "insert video" from the pop out and browse to your video and select it - does VideoStudio allow you to do that
beno171717
- processor: Apple
- ram: 8Gb
- Video Card: Apple
- sound_card: Apple
Hi BrianCee,
Cheers for the post, i had a mess around with what you mentioned. It eliminated a lot of questions.
I think the issue was that a file I had copied over was corrupt... once it was deleted all the files loaded properly
