Cannot capture either on X4 or X8
Re: Cannot capture either on X4 or X8
Post by BrianCee »
OK - carried out some tests
VideoStudio X8 on Windows 7 professional - using Panasonic GS300 camera connected by firewire
I can capture with no problems at all - not only capture but have full control
for me there are no problems.
Brian -- I assume you have the full version of X8 on that computer, and not the trial version...?
Post by BrianCee »
Yes - I have the full version
that was the purpose of the test - to see if the fact that Pavel has the trial version *MAY* be the reason that the firewire capture doesn't work
Pavel
Post by Pavel »
Hi, it finally all works as I wished! Ken, Brian thanks a lot for your patience and help.
Initially, the system did not want to install camera driver with the legacy driver, then it installed Microsoft driver for DV cameras and I only could capture DV instead of HDV. I do not know what I did :D but after a few trials I managed to install Canon HV30 driver and covered this all on top by the paid version of VS and now it works exactly as I wish. Thanks a lot guys for the time you invested into my issue!
ottersea
motherboard: Biostar
processor: Intel duo core
ram: 2gig
Video Card: Nvidia GForce 8400
Hard_Drive_Capacity: 1.7 TBytes
Monitor/Display Make & Model: Viewsonic VA2431
Post by ottersea »
I,m back. So I guess I toasted the canopus because I cannot even change from digital in to analog in. It just has both light lit and will not change. Anyway I got a USB diamond VC5oo and it will capture in X4 but for some reason it will not capture in X8. When I try to capture it gives the error "Unable to switch to capture mode. Check if your video capture driver is working properly" I have checked the driver and it says it is working properly and apparently must be because it works in X4. Any ideas how to get it working in X8?
Post by BrianCee »
I don't know the Diamond VC500 but many of those capture devices - and I have one of a different make - are "tweaked" so that they only work with the software supplied with them and it is probably just a coincidence it works in X4.
Did you get any software with the device - can you capture using that ? and import to VideoStudio.
ottersea
ram: 2gig
Post by ottersea »
Yes I can use the bundled software or use X4 to capture. I have not tried to import yet as I just used X4 to capture and seems to work good. I have not imported X4 to X8 or the capture card to X8 yet. I am just trying to cut down some steps.
