Rotate Text Around Sphere
Post by Black Lab »
Has any one had experience making text rotate around a sphere? I was working on it last night and just couldn't get it right. Any tips would be appreciated.
OinkyPig
Post by OinkyPig »
I tried as a newbie to make it. I am not sure whether it is the correct way to do it
There was 2 ways I tried:
1) Make a sphere and then using texture choose a JPEG file with the text on it. So the sphere rotates (animated) and the text rotates along with it
2) Make a text object and under the attribute panel <Add a plug in> which you can choose a plug in labelled Surface Animation which you can choose a sphere shape. Then make a sphere with the same co-ordinates and increase the transparancy so that the text can be seen.
Maybe some one knows a better way to do so... I also tried for a long time trying to do so.
Cheers
pauley
Post by pauley »
One of the included samples has text going around a globe. That should show you the best way to do it, and you may even be able to use that example.
Pauley
