zPerspector for ASP 2.2
tintin
- processor: Ryzen R5 3600X
hi,
after long time, i finally was able to port the next plugin to ASP2.2 under Qt5.4...
attached below there are 2 packages.
zPerspector_WL.afzplug : 32 bit, Win + Linux
zPerspector64_WLM.afzplug : 64 bit, Win + Linux + Mac
edit: due to some legal aspects i again had to remove the plugin packages here. The plugin is sent to Corel to be put on the official plugin homepage of ASP. Thank you for understanding!
tintin
happy perspecting!
br
tintin
ps: the other plugins will also follow step by step...
tintin
happy perspecting!
br
tintin
dsigman
- motherboard: ASUS A78M-A
- processor: AMD A8 6600K
- ram: 8 GB
- Video Card: ASUS R7 250X
- sound_card: AMD High Definition
- Hard_Drive_Capacity: 1 TB
Re: zPerspector for ASP 2.2
Thanks. Great to have it back.
Arnfinn
- motherboard: ASUSTeK Computer INC. SABERTOOTH X58 Rev 1.xx
- processor: Intel Core i7 CPU 960 3.20GHz 3.20GHz
- ram: 12 GB
- Video Card: NVIDIA GeForce GTX 670
- sound_card: High Definition Audio Device [5x]
- Hard_Drive_Capacity: 12 TB
- Monitor/Display Make & Model: BenQ G2400W 24,0" + Acer X203H 19,9"
- Corel programs: ASP
Thanks for the 2.2 compile, TinTin
However, on my 64 bit Windows 8.1 there is a strange grid over the image when the plugin is enabled (grid radio button off). The grid is visible both on the image on screen and on the exported image. On screen it is large squares, but on the exported image the grid squares is much smaller. The (strange) grid overlay is unchanged by any settings or values within the plugin.
Here is an example of the grid when the plugin is enabled... This is how it looks like when the grid radio button is enabled on the same image... This is the output image without grid enabled. The grid size is smaller than the one I see over the image on screen.
Long time AfterShot Pro & Bibble user...
http://creativewithlight.com/
tintin
Mh.
I've not seen that before...
I'll check it asap.
Anybody else with same or similar issue?
Br
Tintin
I'll check it asap.
Br
Tintin
tintin
hi,
i checked it today again, but i couldn't see this phenomena on my win8 (64bit) machine.
i plan to have some additional tests tomorrow - maybe i have to prepare a test-version for you...
br
tintin
br
tintin
dFlyer
- System_Drive: N/A
Tried to reproduce this on Windows 7 and couldn't. Everything seems to work correctly.
Thanks.
Gary Garibaldi
Linux since 96
Sony a700
Sony a100
Gary Garibaldi
Linux since 96
Sony a700
Sony a100
Dutchmm
- System_Drive: N/A
- motherboard: Asus 97
- processor: Intel i7 4785T
- Video Card: Onboard Intel
- sound_card: Intel AC97
- Hard_Drive_Capacity: 2.5TB
- Monitor/Display Make & Model: Philips 28"
- Corel programs: ASP 3 Pro (and 2 and 1 before)
I can't see the unwanted grid on my W8.1 (64bit) laptop either.
AsterixEtObelix
- System_Drive: N/A
- motherboard: Debian squeeze 64
- processor: Intel
Hello,
this things happen to me all the time when I am using zPerspector on Linux, and even with ASP 1 (I am only using ASP 1)
hopefully there is a workaround which work all the time: just crop the picture with the crop tool (even to the max) and those lines magically disappear.
nevertheless if I do not crop the pict it is not seen on the exported picture. So for me this bug is not really annoying.
cheers
cheers
martvi
- System_Drive: L
- motherboard: Asus Unknown
- processor: AMD Athlon 4
- Video Card: NVidia GeForce 8600
- sound_card: Unknown
- Hard_Drive_Capacity: 26 TB
I see the artificial grid only when I use the default Sharpening from ASP (Basic Adjustments) together with zPerspector. I have several examples. This does not happen with all of my photo's however. If you need an example, I will upload one to Dropbox.
BTW: I use ASP 2.2 on Linux.
Arnfinn
- ram: 12 GB
It's the default sharpening for me also. I clicked it off before enabling zPerspector, and this time NO grid on screen or on export. Looks like this causes the problem on both Linux and Win 8.1/64...martvi wrote:I see the artificial grid only when I use the default Sharpening from ASP (Basic Adjustments) together with zPerspector.
Arnfinn
- ram: 12 GB
Given the rate they have updated the ASP plugin page in the past, it should be approx. 6 months before it's available there...tintin wrote:edit: due to some legal aspects i again had to remove the plugin packages here. The plugin is sent to Corel to be put on the official plugin homepage of ASP. Thank you for understanding!
tintin
dFlyer
- System_Drive: N/A
Any word on when they will be posted on the official plugin site?tintin wrote:hi,
tintin
happy perspecting!
br
tintin
Thanks.
Gary Garibaldi
Linux since 96
Sony a700
Sony a100
Gary Garibaldi
Linux since 96
Sony a700
Sony a100
tintin
all i can say is, that i got an email with an acknowledge of receiving my mail and that they will test it and put on the official plugin page - that's been 3 weeks ago now. i did not get any other info, yet.dFlyer wrote:Any word on when they will be posted on the official plugin site?
br
tintin
I found version 3.0.0 on the ASP site today:
http://www.aftershotpro.com/en/plugins/zperspector/
Is that the latest version?
I downloaded the 64-bit version and installed it (ASP 2.2.0.29). It seemed to install OK, and if I try re-installing it correctly asks if I want to replace the existing version. But I cannot find the plugin anywhere to use it. I have restarted ASP (multiple times)
It is not listed on the Plugins page, and it is not listed under plugins if I go to Help > System Info.
Am I looking in the wrong places, or is the version currently available at ASP plugins still not the 2.2 64-bit compatible one?
Hobgoblin
- System_Drive: N/A
That's the earlier version.kiwi wrote:I found version 3.0.0 on the ASP site today:
It will be 3.1.0 for the ASP 2.2 version.
Now available on the Plugins page http://www.aftershotpro.com/en/plugins/zperspector/
