opening images as layers
oldtap
motherboard: 1.0 133MH
processor: Intel Core i3 530 2.93 GH
ram: 8 GB
Video Card: NVIDIA GeForce GT 220
sound_card: NVIDIA 4x
Hard_Drive_Capacity: 1 TB
Monitor/Display Make & Model: LG W2753
Post by oldtap »
Hi all.
I'm sure my problem is something I am doing wrong. All I want to do is make a collage of three or four images but I can not open more than one image at a time. How do I get the images into the layers pallet so I can edit from there. I can not find anything in the user guide that will tell me how to do it. I watched and tried the video tutorial intro to layers in PSP x5 but that didn't work for me either. I am using PSP x4 and I have spent hours trying to figure this out.
Thanks,
oldtap.
Forriner
motherboard: ASUS Z170M-PLUS
processor: Intel Core i5-6400
ram: 16 GB
Hard_Drive_Capacity: 1250 GB
Monitor/Display Make & Model: Philips Brilliance 272b 2560 × 1440
Corel programs: PSP 2023
Re: opening images as layers
Post by Forriner »
You say you can't open more than one image at a time. I wonder if you're using 'tabbed documents' so you can only see one at a time but have several open with tabs at the top?
If so, open the Windows menu and check if 'Tabbed documents' has a check mark. Click on it to uncheck it, and you can then see every open image, cycle through them and move them around the workspace.
Then you can copy an open image and paste it as a new layer into another document.
photodrawken
ram: 16Gb
Hard_Drive_Capacity: 324Gb
Post by photodrawken »
oldtap wrote:How do I get the images into the layers pallet so I can edit from there.
1. Show the image you want to copy.
2. Use Ctrl+C to copy it to the Clipboard.
3. Show the target image.
4. Use Ctrl+V to paste the copied image into it as a new layer.
5. Repeat as necessary.
There's no need to show all the images at the same time.
Ken
Forriner
ram: 16 GB
Post by Forriner »
You can also copy a layer from one image to the other by opening the layer palette and dragging the layer button from the source image to the target image. The target image itself, not the layer palette.
motherboard: Alienware M17xR4
ram: 6 GB
Hard_Drive_Capacity: 500GB
Corel programs: PSP: 8-2023
Post by LeviFiction »
There is also a script out there that will actually open an image as a new layer. This script can open as many images at 1 time as you want and copy them all as individual layers into the current document.
Can be downloaded from here: Open As Layer Script
Who knows maybe one day I'll even make it a smart script. Right now it just takes the first selected layer in the image and copies that. So if you're feeling lazy, and don't mind using the standard Open dialog (won't work from the manage mode) this script is for you. *cheesy smile*
oldtap
ram: 8 GB
Post by oldtap »
Thank you all,
I knew it was something I was doing wrong. Everything is working the way it should and your quick replies are much appreciated.
Thank you,
oldtap.
