PSP X3 - Convert Nodes to Curves script
TXShooter
motherboard: Hewlett-Packard 3612 09.67
processor: 2.20 gigahertz Intel Celeron 900
ram: 2GB
Video Card: Mobile Intel 4 Series Express Chipset Family
sound_card: Conexant Pebble High Definition SmartAudio
Hard_Drive_Capacity: 250.06 GB
Monitor/Display Make & Model: Generic PnP Monitor (15.3"vis)
Post by TXShooter »
I'm creating vector paths and having to go back to 'doctor' them up after being drawn. One issue that I'm having is how much time it takes to edit each node after the fact, and it take three times as long having to convert each one into a 'smooth curve', before and after. Are there any means of moving the right-click sub-menu into a menu bar for quicker access??
motherboard: Alienware M17xR4
ram: 6 GB
Hard_Drive_Capacity: 500GB
Corel programs: PSP: 8-2023
Re: Quicker sub-menu access question (PSP X3)
Post by LeviFiction »
Yes you can.
You can also assign shortcut keys to these commands if you want.
View -> Customize
The customize dialog lets you assign short cuts, create toolbars, edit menus, and context menus (right-click menus).
One thing that I did was I recorded a script using "Curve Before" and "Curve After" and called it "Convert to Curve." I then added it to the context menu to quickly perform that function. I also double-click on a node to select all of the nodes in a contour and use that script to convert all the nodes all at once.
TXShooter
ram: 2GB
Post by TXShooter »
LeviFiction wrote:Yes you can.
View -> Customize
Now THAT sounds exactly like what I'm wanting to do.
I just created the 'menu', now I just gotta learn how to record scripts. I'm finding that I'm not so much an expert of using PSP as I thought I was as time goes by. (Baby steps.)
ram: 6 GB
Entertainingly, I have an old video made with PSPX3 about recroding a script and adding a menu item for converting a node to a curve.
http://www.youtube.com/watch?v=AxtEpQXe-0I
