Quickly add symbol to currently open image?
terrypin
motherboard: Asus Z170 Pro 4
processor: Intel Core i7 6700K 4.0GHz
ram: 32 GB
Video Card: None - uses built-in graphics
sound_card: HD onboard sound card
Hard_Drive_Capacity: 4.256 TB
Monitor/Display Make & Model: iLyama Prolite E2403WS 24" 1920x1200
Corel programs: Paint Shop Pro 8; Paint Shop Pro 2018
Post by terrypin »
I frequently need to paste a specific JPG into the image I currently have open in PSP 8.
https://dl.dropboxusercontent.com/u/401 ... mbol-1.jpg
What would be the quickest way of doing that please? Ideally as a new layer in case it needs resizing.
It's pretty quiet there, but I'll also post this to the corel.PaintShopPro_Scripting newsgroup in case there's a way of achieving this with a script.
Terry, East Grinstead, UK
Using PSP 8 & PSP 2018 under Win 10
Kathy_9
Hard_Drive_Capacity: 2TB
Re: Quickly add symbol to currently open image?
Post by Kathy_9 »
Picture tube?
terrypin
ram: 32 GB
Post by terrypin »
Thanks Kathy. I thought of that subsequently but I've just been trying it and not found it very successful. I made a single image tube and eventually after fiddling with the settings I was able to place it at the position of the mouse cursor click. But its position cannot then be adjusted it would seem?
So at present I'm opening up the symbol folder (from a desktop shortcut) and then manually dragging in the symbol of choice as a new image, copying it and then pasting into the target image.
I'll now use my macro program (Macro Express Pro) to automate that for one specific symbol.
Am I right that scripts can't handle file operations?
Kathy_9
Post by Kathy_9 »
Hi Terry - I don't know of a way to accurately place a picture tube exactly where I want it so I will usually add it to a new raster layer and then used the pick tool to re-position and or re-size it.
motherboard: Alienware M17xR4
ram: 6 GB
Hard_Drive_Capacity: 500GB
Corel programs: PSP: 8-2023
Post by LeviFiction »
Scripts can handle file operations just fine. Though you have to place such scripts in your scripts-trusted folder. That folder is for scripts that you trust to have greater access to your computer.
In fact, so long as you never change the location of the symbol you want to add you can just record a script direct inside of PSP that will always do what you want.
1) Hit Record on the scripts toolbar
2) Open symbol
3) Copy symbol
4) Close symbol
5) Paste as new layer
6) Save the script to your scripts-trusted folder
Now anytime you run the script it'll open the symbol image, copy it, close that image, and paste the symbol as a new layer.
You can also, since you have the picture tube made, create a script that creates a new layer, and then stamps the picture tube at a specific location.
Forriner
motherboard: ASUS Z170M-PLUS
processor: Intel Core i5-6400
ram: 16 GB
Hard_Drive_Capacity: 1250 GB
Monitor/Display Make & Model: Philips Brilliance 272b 2560 × 1440
Corel programs: PSP 2023
Post by Forriner »
Hi LeviFiction and terrypin,
Please correct me if I'm wrong, just trying to help.
If I'm right, when you close an image in PSP, PSP activates the last active window?
So if there are several files open, make sure the image you want to paste the new layer to is active before running the script later when you use it, right?
Another point: In PSP X4 anyway, when you run a file open script, the file open dialog opens with the file name used when you recorded it. You can then navigate to another file or just hit 'open'. You can edit the step in the script to 'silent' open if you always want to use the same file, so you don't get the dialog.
ram: 6 GB
You are correct.
You can, however, make the script more intelligent if you're willing to make some small changes to the code. By more intelligent you can make certain actions silent, and you can force certain actions to always be performed on a specific document.
With these edits, so as long as you run the script on the image you intend the symbol to appear on, that image will always receive the "PasteAsNewLayer" command.
Loosely speaking the idea is to create a variable after the "EnableOptimizeUndo" command.
Code: Select all
CurrentDoc = App.TargetDocument
Then, after the last "}" and before the last ")" on the command "PasteASNewLayer" you add
", CurrentDoc"
It'll look loosely like this
Code: Select all
App.Do( Environment, 'PasteAsNewLayer', { ... , 'GeneralSettings':{} } , CurrentDoc )
That forces the command to execute on the image that was active when the script was run.
Forriner
ram: 16 GB
Post by Forriner »
Thank you, LeviFiction.
terrypin
ram: 32 GB
Post by terrypin »
Many thanks LeviFiction, that's good news. I'm inexperienced with PSP's Python scripting and recall from past attempts that it's strict about exact syntax. But I'll set aside time soon to try developing one along the lines you've outlined.
However, as a non-programmer, I am comfortable with Macro Express Pro and now have two macros working: one to add my Walkers symbol as a new selection, the other as a new layer, activated by a hotkey while the target image is open in PSP 8.
