[SOLVED] Batch process: Add filename as watermark to images
gba
operating_system: Windows 8.1
processor: AMD A8-4500M APU with Radeon HD Graphics
Hard_Drive_Capacity: 750GB
Monitor/Display Make & Model: Philips 273E-QH
Post by gba »
Hello PSP pros!
I have about 200 BMP images.
And I want to add the corresponding filename as a visible watermark to each image.
How would you do that?
Best regards,
Gerald
Tony Lenton
motherboard: Intel DH55TC
processor: Intel Core i5 3.20 GHz
ram: 12GB
Video Card: GeForce GTX 1060
sound_card: On board Realtek High Def Audio
Hard_Drive_Capacity: 4500 GB
Monitor/Display Make & Model: Lenovo S27i
Corel programs: PSP X6 PSP2020
Re: Batch process: Add filename as watermark to images
Post by Tony Lenton »
Hi Gerald
Try this script, you may need to edit it to suit. Place it in your Trusted Scripts folder.
Rename the script to Add Filename.PspScript for some reason I couldn't upload it with the correct extension.
Add Filename.txt
(7.02 KiB) Downloaded 418 times
gba
SOLVED: Batch process: Add filename as watermark to images
Post by gba »
Hi Tony!
Thank you for your quick response.
That worked - great!
Best regards,
Gerald
