Workaround for Nik Plugins on PSP X6
JoeB
operating_system: Windows 8.1
ram: 8 GB
Hard_Drive_Capacity: 4.6 TB
Re: Workaround for Nik Plugins on PSP X6
Post by JoeB »
Jan Shim wrote:Although I said I wouldn't contact JSJ directly, I did ... I was bothered (last night) by how close to perfection the script is except for the error flag. It's strange how you can continue to work on images all day long and there would be no errors, until you close the application. I wondered if the others are experiencing this too. Everyone's been quiet.
I was wondering that myself. But maybe some of them are not having issues (depending on their PSP version as well as their operating systems), and maybe others have the minor problem I have that is easily handled by just closing the error box so haven't bothered about bringing it up. But with both of us contacting JSJ perhaps we'll hear something. Don't know if I'll be able to reply to anything coming in about this until I get back next week, but I'll see.
JoeB
jsj
Post by jsj »
Hi all.
Sorry to not follow this forum but nowadays I'm not using Corel PSP anymore.
That error you talk about, happened to me from time to time also when I used PSP. Because of this I dropped this program and now I use Photoshop and/or The Gimp.
I think the error is caused by some incompatibilities between the code that Corel uses to handle the plugins and the plugin himself. In fact I only use his scripting language. And the original code was generated via macro-recording and some "hand-made" modifications to change some parameters. So I don't know exactly why this code could drop that error because is code auto-generated by Corel macro-recorder.
Sorry not to be of more help. Best regards.
JoeB
ram: 8 GB
Post by JoeB »
Thanks for your reply, jsj. In my case the error is of minimal inconvenience because PSP closes properly and I just have to close the error popup so I'll be continuing to use your scripts. Thanks!
JoeB
EDIT: I haven't had this error for quite some time now (it's now February, 2018), maybe because of some minor edits I have made to the script over time but not sure which ones might have fixed things. Could also be because I am using a newer version of PSP (X9 and 2018). Just thought I'd mention that in case others had the issue but maybe with older PSP versions. If it's the newer versions that don't have issues then no reason for concern about my initial post.
