Save Preferences Script
motherboard: Alienware M17xR4
ram: 6 GB
Hard_Drive_Capacity: 500GB
Corel programs: PSP: 8-2023
Post by LeviFiction »
Hello, anyone who reads this board. :D
So in the X8 wishlist topic I told a couple of people to give me 1 day and I would make a Save Preferences script. And I did. I just forgot all about it and so never told anyone.
It was also more or less just a proof of concept script. Very simplistic. And very ugly. It comes in two scripts, you have to manually program in the file location in both of them. The first script is a save script. The second is the load script. Using these you could easily save your preferences for read-back later. And provided PSP doesn't change those preferences too much between versions it should also technically work regardless of which version of PSP the preferences come from. I've only tested this with X6 and X7 though. SO I make no guarantees.
You can download the scripts here - https://drive.google.com/file/d/0B8FlFL ... sp=sharing
By default the script runs silently so once it's done saving it's done saving. There is no notification of completion. If you prefer to see a pop-up letting you know then download this alternative set. These scripts will send a short pop-up at the end of the script if it's successful.
The scripts should be installed in the "Scripts Trusted" folder because they use libraries and save files to your hard drive.
Here's a video demonstrating its use - https://www.youtube.com/watch?v=S_CoGttsL2c
Kathy_9
Hard_Drive_Capacity: 2TB
Re: Save Preferences Script
Post by Kathy_9 »
Very slick - thanks!!!
Jean-Luc
Hard_Drive_Capacity: 2 Tb
Post by Jean-Luc »
LeviFiction wrote:Hello, anyone who reads this board. :D
Very clever ! Thank you !
I don't understand why Corel itself didn't provide us this sort or script with each version of PSP!
:roll:
Jean-Luc
KathyB
motherboard: Alienware 068R5X A03
processor: 2.70 gigahertz Intel Core i7-4800MQ 64 kilobyte pr
Video Card: NVIDIA GeForce GTX 770M
sound_card: NVIDIA Virtual Audio Device WDM
Hard_Drive_Capacity: 4500.48 Gb
Monitor/Display Make & Model: Alienware Alienware 17 A07
Post by KathyB »
Thank you :D
KathyB
arturox
motherboard: Yes-very-bored
processor: 3-90 gigahertz Intel Core i3-7100
ram: 8 Gigs
Hard_Drive_Capacity: 250Gb SSD+1 Tb SSD
Monitor/Display Make & Model: Acer 22 inch
Corel programs: PSP 9-01 and PSP 2022
Post by arturox »
Long time since LeviFiction's original posting, but I've only just been pointed at it.
This is a most excellent bit o' scripting Levi, something we've needed for a long time.
Thanks, much appreciated.
Arturox.
FWIW. I've also tried it out on PSP 9.01 and it worked okay.
Ax
Jean-Luc
Post by Jean-Luc »
Just a suggestion ...
When backingup the Preferences, after the saving I would see a pop-up window saying :
"Your preferences are now saved and stored here : ".. folder xxx ... etc. "
This window permits also to know that the job is done. Actually, the saving is silent and nothing is visible saying "ok, done" ... For first time users, it would be better.
ram: 6 GB
Done, edited original post to include the msgbox as a separate option.
trueblue
Moderator
motherboard: ASUS Z97M Plus
processor: Intel Core i7-4790 CPU 3.60 GHz
ram: 12GB
Video Card: NVIDIA GeForce GTX 750
sound_card: NVIDIA High Def Audio Realtek High Def
Hard_Drive_Capacity: 1.740GB
Monitor/Display Make & Model: Benq E2420HD 24" wide x 2 monitors
Corel programs: PSPX8-VideoStudio-AfterShot
Post by trueblue »
Thanks Levifiction, this is a super script and will be most useful.
~~~~Maureen~~~~
Creative-Designs
Free! PaintShop Pro Tutorials
Cassel
ram: 16Gb
Corel programs: PSP 8 (JASC) to PSP 2023
Post by Cassel »
Matthew, do you know how far back this script can work for different versions of PSP?
Is it limited to X8 and up?
Cassel
https://scrapbookcampus.com
Cassel
ram: 16Gb
Post by Cassel »
Another question: where is the data saved?
If someone wants to save their preferences before installing PSP on a different machine for example, where would the 'file' be that they would need to grab and copy from?
Cassel
ram: 6 GB
It attempts to save the file to the Workspaces folder. If you watch the video linked in the original post it shows you how to edit the script to change the location of the file should you choose to do so.
I only tested back to X6. However, it relies on the PSP API to return the preferences settings. So as long as the version of PSP supports the command and returns all of the necessary information it should work in most versions of PSP. For an exact limit, you'd have to test it yourself. It's honestly an extremely simple script it's not doing anything too fancy.
Cassel
ram: 16Gb
Post by Cassel »
Thanks. I ran it and the file was not saved in the Workspace folder, but instead, on the parent folder of the Workspace folder.
Not sure if it is typical or what. Just letting you know.
Cassel
ram: 6 GB
Well, i said it would try to save it to the Workspaces folder. If you use the defaults and don't edit the script at all it grabs the first location returned by the File Locations dialog. In the video you see it goes into my Workspaces folder. So, no, it's not typical for it to save outside of the workspaces folder.
Code: Select all
os.path.join(files['Workspaces'][0], FilePref)
So it's not like the code leaves out a folder location. It all depends on what that first value is and if PSP or Python or Windows do any kind of re-routing if that first location is not in your Documents folder. Which I don't believe any of the do reroute. They usually just throw an error if you try to save to an invalid location.
JoeB
operating_system: Windows 8.1
ram: 8 GB
Hard_Drive_Capacity: 4.6 TB
Post by JoeB »
I just tried this script, and while it works in X7 and X8 it won't load in X9. The problem is here line 2 - and I'm curious about what's with the pickle??
Executing RunScript
Traceback (most recent call last):
File "<string>", line 2, in <module>
ImportError: No module named pickle
JoeB
Using PSP 2019 64bit
ram: 6 GB
pickle is Python's serialization format. It makes saving and restoring native Python data very fast.
Make sure you have the latest patches for X9, the official version of PSP did not come with all of the python libraries. I think you need to specifically install Patch 1 before other patches. This was the result of Corel trying to make the download smaller. Did not go over well.
