PSP X2 Duplicates Found
MenaceRx
motherboard: Azrock 970 Extreme 3
processor: Phenom II X6 1090T Extreme
ram: 16Gb
Video Card: Power Color 7850 2GB
sound_card: Creative Sound Blaster Recon 3D
Hard_Drive_Capacity: 3TB
Monitor/Display Make & Model: HP 22Inch 1080p
Post by MenaceRx »
I have never seen this before in all my years of using PSP. I have X2, X3, and X6 currently. X2 is my preferred version and the one installed right now.
I did a windows update recently, dont know if they could cause it or something else. I havent done any PSP updates that I know of recently.
I watched a video that shows a .bat file that can do a cleanup but that file is no longer hosted. Any one have some simple instructions on how to clear this up.
MarkZ
ram: 8 GB
Hard_Drive_Capacity: 500 GB
Re: PSP X2 Duplicates Found
Post by MarkZ »
How did you get to this showing as an error file and what makes you think these are errors? It would be useful to know how you got to this list.
These files are the Patterns that you use in X2. Open some of the .jpgs to confirm. There is a separate directory of the patterns, tubes, swatches, etc. for each version of PSP. In later versions these items were stored in different locations than what you show.
Mark
JoeB
operating_system: Windows 8.1
ram: 8 GB
Hard_Drive_Capacity: 4.6 TB
Post by JoeB »
Check your Preferences>File Locations and click on Patterns and see if you have shown a path to two different folders for the same patterns.
JoeB
Using PSP 2019 64bit
MenaceRx
ram: 16Gb
Post by MenaceRx »
Thanks. So what I did was go under preferences and reset all settings to default. It was popping up that error beccause of multiple locations, which is odd, because I installed and patched PSP X2 on my new SSD months ago and it didnt do this initially.
So I just went to File -> Preferences - Reset Application Preferences. Now everything functions as normal. Told it to clean up all the old caches and reset everything to factory install settings.
MenaceRx
ram: 16Gb
Post by MenaceRx »
MarkZ wrote:How did you get to this showing as an error file and what makes you think these are errors? It would be useful to know how you got to this list.
They pop as an error on start, guess somewhere along the line I ended up with multiple caches confusing the program. I assume it happened when something got patched or updated. Though I dont know when or what.
