If the Smartsound software has become corrupt somehow, Have you tried uninstalling and restoring the Smartsound package as suggested at this link?
http://howto.corel.com/en/c/How_to_rest ... _or_Pro_X4
Project won't open!!
trailryder42
- motherboard: Gigabyte GA-890FXA-UD5
- processor: AMD Phenom II x4 965 3.7Ghz.
- Video Card: Nvidia GTX 560Ti
- sound_card: On Board Realtek ALC889
- Hard_Drive_Capacity: 256GB+3TB
- Monitor/Display Make & Model: Samsung Syncmaster 941BW
newfielander
- motherboard: NVIDIA NFORCE 780i SLI 2
- processor: Intel r Core TM2 Extreme CPU Q6850 3.00GHz
- ram: 16 GB
- Video Card: Geforce 8800 ultra
- sound_card: onboard
- Hard_Drive_Capacity: 1000gb
- Monitor/Display Make & Model: HP 2311 [Monitor]
Re: Project won't open!!
Hi trailryder42
Thanks for your input, like I said earlier,I'm willing to try anything! But yes I tried that already and with both SmartSound Common data and Smart Sound Quick tracks 5 removed from my computer the project nearly opens, I can see everything in the project but ofcourse the error is on the screen and I can't click save or anything until i X out the error and when I do that than Corel closes. I have since reinstalled a new copy of SmartSound Common data and Smart Sound Quick tracks 5 and still no luck.
Here is the details of the error that I get.
Problem signature:
Problem Event Name: APPCRASH
Application Name: vstudio.exe
Application Timestamp: 52bb3bf3
Fault Module Name: HerDocdll.dll
Fault Module Version: 17.0.0.249
Fault Module Timestamp: 52bb358b
Exception Code: c0000005
Exception Offset: 00000000000c5ac5
OS Version: 6.1.7601.2.1.0.256.48
Locale ID: 1033
Additional Information 1: 267c
Additional Information 2: 267cf222fa361865186e47e674b13f12
Additional Information 3: 6c50
Additional Information 4: 6c503ccd41d5a2fc538413bdfab9ce4d
Problem signature:
Locale ID: 1033
trailryder42
After using Add/Remove Programs to remove the software, are you using any kind of Files Cleaner like CCleaner afterward to rid any leftovers from the system and registry? It's been my experience that sometimes Windows Uninstaller doesn't get everything, then when you go to reinstall, if there's a corrupt file or entry still on the system, instead of the reinstall process over-writing a file or entry that's already there, it just installs whats needed and so a corrupt file or entry may remain with the fresh install.
newfielander
- ram: 16 GB
Hi actually I have a great program to do that but never thought to do it, I will do it right now, I'll report back shortly>>>.......................... NO LUCK
Here is what I get now.
newfielander
- ram: 16 GB
have there being any solution found to this problem, it as happened AGAIN !!!!! Just about finish my project and it wont open. So frustrating!!
That’s not good for the start of a New Year
Is this the same project as you provided earlier, or a different one.
I noticed from the fault details that you have not updated the program, have you tried installing the service packs for X7.
I also assume you have re-installed the program, uninstall selecting to remove all personal data to perform a clean install.
Having said that I cannot open the VSP, something has certainly corrupt that?
I did pass on your details with the VSP to Corel but have not heard anything positive, other than it was passed on to Technical support
newfielander
- ram: 16 GB
Its a different project, but I would imagine it will be my last with Video studio.
Hi newfielander
Sorry to hear that but can understand your reasons, having the program crash is bad enough but unable to recover the project is ……
If you attach your latest problem file I will pass on to Corel again.
At the moment they are pretty busy with a flash update SWF problem, program crashing but sure they will reply, I can only try again?
