Hello,
I found a hint how to use the distortion data form the lensfun project with AfterShot. Similar to other blocks in the file profile_panasonic.txt, i replace the block with FZ200 in it with the following:
begin lens
group: panasonicFZ200
multiplier: 5.56
menu_lens: Standard
cal_abc: 4.5 0.02263 -0.08126 -0.02068
cal_abc: 6.4 0.02901 -0.09166 0.02698
cal_abc: 6.6 0.03178 -0.10015 0.03574
cal_abc: 9.1 0.01355 -0.0436 0.00536
cal_abc: 11.4 0 -0.01092 0
cal_abc: 18.7 0.01289 -0.04634 0.02406
cal_abc: 21.8 0 -0.00838 0
cal_abc: 33 0 -0.00853 0
cal_abc: 39.1 0 -0.00806 0
cal_abc: 53.4 0 -0.00832 0
cal_abc: 74.3 0 -0.00968 0
cal_abc: 108 0 -0.00966 0
end
begin camera
multiplier: 5.56
menu_make: Panasonic
menu_model: DMC-FZ200
exif_make: Panasonic
exif_model: DMC-FZ200
end
These parameters are working fine with AfterShot and the FZ200. Is it possible to include all the data form the lensfun project in AfterShot - maybe in a future version ?
Regards, Marko
Lens correction via lensfun project
bifer
- processor: i7-4720 HQ 2.60 GHz
- Video Card: NVIDIA GeForce GTX 960M + Intel HD4600
- Hard_Drive_Capacity: SSD 1+2TB
- Corel programs: ASP3, PSP2018 + VS2018 Ultimate
Re: Lens correction via lensfun project
Just for an example I've edited the profile_panasonic.txt to include my Panasonic Lumix DMC-LX100 based on the parameters found in the lensfun project. The distortion correction from lensfun isn't correct. It looks like I have todo all the calibration myself. ASP2 is disappointing me more and more and I really started to "use (trying to use)" it a few days ago.
FotoLars
- System_Drive: X
- motherboard: Intel D975XBX2
- processor: Intel QuadCore Q6700
- ram: 8 GB
- Video Card: NVIDIA Quadro NVS 295
- Hard_Drive_Capacity: 8 TB
- Monitor/Display Make & Model: 2xDell 30", 5120x1600 (2x2560x1600)
Hi bifer,bifer wrote:Just for an example I've edited the profile_panasonic.txt to include my Panasonic Lumix DMC-LX100 based on the parameters found in the lensfun project. The distortion correction from lensfun isn't correct. It looks like I have todo all the calibration myself. ASP2 is disappointing me more and more and I really started to "use (trying to use)" it a few days ago.
If you can get access to a linux based environment, or possibly setup a cygwin environment, you can follow the calibration procedure that I describe in http://forum.corel.com/EN/viewtopic.php?f=95&t=45815.
The correction values become as correct as much effort you put in when taking the suitable calibration photos and performing the calculations - if you are calibrating a zoom lens, change the focal length maximum 10% before you take a new photo, all with a good and the same background, please see some of the photos attached for how a descent background needs to look. afx provided a very handy script (http://forum.corel.com/EN/download/file.php?id=2537) that automates some of the handling quite a bit - please read a bit in the thread...
I calibrated a number of Nikkor and 3rd party lenses for Nikon, and equipped BibbleLabs/Corel with these values, so they are since long included in the default lens calibration data file.
If you are careful and ambitious when taking photos and performing the calibration, you can get better correction than the usual commercial RAW handling programs available provide
Cheers and good luck,
Lars Nilsson
Lund, Sweden
bifer
Thanks for the suggestion.FotoLars wrote:Hi bifer,bifer wrote:Just for an example I've edited the profile_panasonic.txt to include my Panasonic Lumix DMC-LX100 based on the parameters found in the lensfun project. The distortion correction from lensfun isn't correct. It looks like I have todo all the calibration myself. ASP2 is disappointing me more and more and I really started to "use (trying to use)" it a few days ago.
If you are careful and ambitious when taking photos and performing the calibration, you can get better correction than the usual commercial RAW handling programs available provide!
Lars Nilsson
Lund, Sweden
Sorry I'm not that familiar with Linux or even cygwin of that matter. This isn't a option to me.
Even I have a lcp for that camera someone made and published in the internet I'm not able to get a lensfun version of it due to the fact of not being familiar with Linux or cygwin.
