Creating an outline with psp7
Bettymcl
- Corel programs: Paintshop pro X7
Hi all. I am new to this board and to paintshop pro. I would like to use psp to draw an outline of a map. To be clear, I have scanned a detailed map with place names, topography and such and I would like to create blank outline for my class. It seems an easy thing but I cannot figure out how to do this. All suggestions welcome and thank you for reading. I have paintshop pro 7
Bettymcl
Re: Creating an outline with psp7
Sorry, I am using psp x7
- hartpaul
- ram: 8 Gb
Just to be sure that is PSP 7 and not X7? If the map is against a clear blue background (sea) you can use the magic wand to select the sea color and then hit the delete key and that will give you your map against a transparent background.
Then invert your selection Selections > Invert and do Selections > Modify > Contract by a couple of pixels and then press delete and that should remove the inside of your map. You should then have an outline of your map a cuople of pixels wide and if you fill this with black you have a black outline map.
Kathy_9
- Hard_Drive_Capacity: 2TB
I guess another question is what exactly do you want outlined? For example, if your map is the United States do you want only the outside border of the country as a whole or do you want to include outlines of the individual states?
JoeB
- ram: 8 GB
- Hard_Drive_Capacity: 4.6 TB
If you attach an image of a map that you want to outline it would be easier for people to determine the best way to create the outline you desire.
JoeB
Using PSP 2019 64bit
JoeB
Bettymcl
Thank you for your replies. It is indeed PSP X7 I am using, sorry for that. I would like initially to have an outline of the whole country / map but can see that I would like to be able to apply what I can learn here to other maps .
I have been attempting to use the eraser but this is a long and slow process . I thought there may be another way that I was unaware of. The actual map is in class so I am unable to upload it here at present. All your help and suggestions are appreciated.
Bettymcl
Hartpaul: thank you. I am using PSP x7 but I think I can make your suggestion work. I will try this tomorrow . Thank you
photodrawken
- ram: 16Gb
- Hard_Drive_Capacity: 324Gb
Why not simply download an outline map? Search the Web for "Maps of <place name>" and you'll get thousands of options, including raster images and vector images.
For example, this site:
http://www.eduplace.com/ss/maps/usa.html
has various outline USA maps (and world maps) that explicitly allow for their use in classrooms.
Ken
