install CPSPX7 the next he stands there and not continuous.
Hi Friends excuse my bad English. I have a problem.
when I try to install Corel Paint Shop Pro X7, under contract or license to accept and I click to the next he stands there and not continuous.
does not advance to the Information menu, user name and serial number.
that problem I have.
Thanks for the help you can give me
regards
regards
Jean-Luc
- Hard_Drive_Capacity: 2 Tb
Re: install CPSPX7 the next he stands there and not continuo
Do a clean uninstall (see the specific message on this board about the subject on uninstall).
And reinstall...
Jean-Luc
And reinstall...
Jean-Luc
If a clean reinstall does not work, then you could try setting up a new Profile in Windows. Log onto the computer using that new Profile. Then try installing PSP. If that works, then you can later uninstall the new Profile, but PSP should continue to work.
Hi Jean-Luc and Ken .. I've done it and it does not work, still does not advance the installation.
Thank you for your response.
regards
regards
Jean-Luc
Delete the file you have downloaded and reload another instance.lordchut wrote:Hi Jean-Luc and Ken .. I've done it and it does not work, still does not advance the installation.
regards
Your installation file could be corrupted.
Jean-Luc
Jean-Luc ... hi, I did nothing, still gives the same error.
Jean-Luc
Do you have the possibility to install the same downloaded file on another computer ? If same error, the downloaded file is the culprit IMHO.lordchut wrote:Jean-Luc ... hi, I did nothing, still gives the same error.
Jean-Luc ... hi, if I installed it on my son's laptop and if he runs well, perfect.Jean-Luc wrote:Do you have the possibility to install the same downloaded file on another computer ? If same error, the downloaded file is the culprit IMHO.lordchut wrote:Jean-Luc ... hi, I did nothing, still gives the same error.
Thank you so much
Jean-Luc
Now, it would be interesting to analyse the differences (hardware and software) between the two computers...lordchut wrote:Jean-Luc ... hi, if I installed it on my son's laptop and if he runs well, perfect.Jean-Luc wrote:Do you have the possibility to install the same downloaded file on another computer ? If same error, the downloaded file is the culprit IMHO.lordchut wrote:Jean-Luc ... hi, I did nothing, still gives the same error.
Thank you so much
Jean-Luc
Jean-Luc.
I had the X6 you uninstall it to install the X7 and .... from then on the problem.
First, you don't need to uninstall X6 in order to install X7... They can both remain on the computer as separate programs. Some of us have several versions of PSP on the same computer.
Second, it makes me wonder, though, whether you bought the upgrade version of X7. That would be looking for an earlier version (X6) or else it could be asking you to first put in the serial number of X6 so it can verify that the upgrade was valid. Then you put in the new X7 serial number. But does your son's computer also have X6 still installed on it? If not, then my theory doesn't hold up...
Ken Berry wrote:First, you don't need to uninstall X6 in order to install X7... They can both remain on the computer as separate programs. Some of us have several versions of PSP on the same computer.
Good morning Mr. Ken
that of my son never had Corel Paint Shop Pro.
It is true and X6 X7 could have both.
I thought if I have the X7, I do not need the X6?
so what I eliminated.
the problem is that no installation progresses.
is to give license to accept and no longer follows next.
I put the menu where user name and serial user does not advance
Sorry to bother them much.
greetings.
When you put in the serial number, does any message appear on the screen? If there is a message, can you make an image of it and upload it here as an Attachment, or at least tell us what it says? (What is your native language, by the way?)
