I created a DVD menu at the end of a project and saved the menu. Is it possible to delete that menu file (if there is one) so I can make a completely new menu? I have tried to redo the menu but keep getting items from the old menu I can't get rid off.
Can I delete a saved Menu - X7
alanball
- motherboard: Gigabyte Technology B450M H
- processor: AMD Ryzen 5 3600 6-Core
- ram: 16 GB
- Video Card: NVIDIA GeForce GTX 1660 SUPER
- Hard_Drive_Capacity: 2TB+480SSD
- Monitor/Display Make & Model: ASUS VN247
- Corel programs: VS10, VS2018 Ultimate, VS2021 Ultimate
Alan Ball
Re: Can I delete a saved Menu - X7
just select the menu in the gallery pane of the create disc menu and press the delete key on your keyboard.
or right click on it in the gallery and choose "delete favorites template"
alanball
- ram: 16 GB
Hi Brian,
thanks for reply, not quite sure what you mean. Are you talking about one of the menus that are contained in the share menu when you say the create disc menu?
i.e. the:
1 Add menu
2 Menu & Preview
3 Output
i.e. the:
1 Add menu
2 Menu & Preview
3 Output
Alan Ball
When you save a disc menu template it appears under the "Favorites" tab when in the "Menu and Preview" section of the disc creation module - open the gallery and use the drop down at the top to select 'favorites' and then delete it there.
like this
like this
alanball
- ram: 16 GB
Thanks Brian,
We are at cross purpose's, I did not save the Menu template as a Favourite but just saved it with the project and tried to change the Menu at a later date.
The problem appears to have cleared itself with a bit of messing around (not sure what I did!!).
I have never saved a menu as a favourite so thanks for showing me how
Alan Ball
