adding languages? PLEASE HELP!
solid_nuts
is there any way i can type in arabic with photoimpact XL?
heinz-oz
keenart
Your Operating system determines the language installed.
Install the language in which your document was composed
You must be logged on as an administrator or a member of the Administrators group in order to complete this procedure. If your computer is connected to a network, network policy settings might also prevent you from completing this procedure.
To read a document composed in another language, you must have that language installed on your computer. Many languages are already installed with Windows XP. However, if you have a document that contains:
• A complex script or right-to-left language: Arabic, Armenian, Georgian, Hebrew, Indic, Thai, or Vietnamese
• An East Asian language: Chinese, Japanese, or Korean
Follow these steps to install the language you need:
1. Open Regional and Language Options in Control Panel.
2. On the Languages tab, under Supplemental language support, select the check box next to the language group you want to install.
Notes
• To open Regional and Language Options, click Start, point to Settings, click Control Panel, and then double-click Regional and Language Options.
• To complete the installation of language groups, Windows will restart the computer.
• With multiple languages installed on your computer, you can compose documents that contain more than one language. Recipients of these documents must have the same languages installed on their computer to read or edit the documents.
Return to the Multilingual Document Consultant
PI installs in more than a half dozen languages, but not Arabic.
However, you may be able to compose your language in MS Office, then copy and place the phrase into PI as a graphic image.
Notes
2log
re: adding languages? PLEASE HELP!
If you have Arabic fonts installed on your computer, you can use "Charmap" to type in Arabic words.
Go to Start > Run then type "charmap", this will launch the character map program. Select the symbols you will use and on the bottom part there is a space for "Characters to copy". It will then display the characters you have selected. Then click the Copy button. Use the "Paste" function on the "Edit" menu to get this into PhotoImpact.
_thing
roozbeh007
