Corel VideoStudio X7 Import .AVI ?
BigBankClub
motherboard: Asus P8Z68 Deluxe
processor: Intel 2600K
ram: 32GB
Video Card: ATI Radeon HD 4800 Series
sound_card: Realtek HD
Hard_Drive_Capacity: 512GB SSD
Monitor/Display Make & Model: ASUS PB278Q 27" LED Monitor X 2
Corel programs: Corel VideoStudio Pro X7
Post by BigBankClub »
I'm looking for a solution. I have videos that are in an .avi format. Is there a way to import them without having to convert them to a .mov?
skier-hughes
Microsoft MVP
motherboard: gigabyte
ram: 4GB
sound_card: onboard
Hard_Drive_Capacity: 36GB 2TB
Re: Corel VideoStudio X7 Import .AVI ?
Post by skier-hughes »
AVI and MOV are, in essence, the same thing.
They are both containers, AVI is the windows version, MOV the Apple.
Inside the container you can find hundreds of different file types, some will work with VS others not. Some need the right codec installing to get them to work.
You could use a codec identifier such as Gspot or avicodec to find out what the codec is and then install it.
If that doesn't work, then conversion would be needed, but I would look at converting to something that should work fine with VS, such as wmv.
Maybe tell us where the videos came from, if you are unsure of the codec used, we might be able to ascertain the info required.
Post by BrianCee »
How are you trying to "import" the avi files - you should just be able to right click over the timeline and choose "insert video" then browse to the avi files and select them
is that not working for you ?
BigBankClub
ram: 32GB
I found the problem and it's working now. :o
It was the settings within the software I was using.
Cam Studio ("Screen Capture) was not set to Microsoft Video 1 capture codec.
Now it works 100% :lol:
Thank you
ps: I'd use the screen capture provided by Corel; but in play back the 1st couple of seconds are pix-elated in grey and then it balances out nicely, not sure why? :roll:
