The file may be write-protected ???
Corel VideoStudio X8
Windows 7 64
After I have edited my video file I press Share, selecting a video type and pressing Start.
I tried everything but still getting the message: "The file may be write-protected" [15033;10;2]
Did somebody had the same problem and had chance to resolve it?
Windows 7 64
Re: The file may be write-protected ???
Please try changing / selecting another "file location", it is possible that the selected location on longer exists.
darklowrider
Hi lata,lata wrote:Hi
I googled this same question which led me to this Forum - I tried what you said and voila! (without looking, it was trying to save to a directory on my usb stick which was no longer inserted within the machine) - I simply changed to the directory/folder I wanted, job done and no longer a write-protected issue.
I thought the least I could do was join the community and thank you
skier-hughes
- Microsoft MVP
- motherboard: gigabyte
- ram: 4GB
- sound_card: onboard
Thanks for doing so, it is nice our voluntary work is appreciated now and then
Paulous69
- ram: 16.gb
- sound_card: real tek hi def Audio 6.0.1.7544
- Monitor/Display Make & Model: pnp generic monitor
- Corel programs: corel video studio x7
Hi - have the same problem on Windows 10. So saved the file then removed the edited video tried to save - same error. removed everything except the corel titles and still got the same error. None of the files are write protected. An 1 1/2 hrs of problems - any suggestions. never experienced this before. Thanks Paul
Have you checked the location that Videostudio is trying to save to - does that location exist always - is it trying to save to a USB stick or external hard drive which is not present - try saving to a new location - one which you can see exists
bellsibells
lata wrote:Hi
This saved my day, thank you so much
crossroadsglass
- motherboard: Asus Z97-Pro
- processor: Intel i7-4440K
- ram: 32GB
- Video Card: NVIDIA GTX 970
- sound_card: SoundMAX Integrated Digital Audio
- Hard_Drive_Capacity: 256SSD+4TB
- Monitor/Display Make & Model: Asus ProArt 24" Dual monitors
- Corel programs: VS X9-U, PS Pro X6 (64-bit)
Yep, that's what it was. I earlier moved my File Location. A simple redirect via Browse fixed it. Thanks a Graves Number!
Thank you for your assistance. I'm very grateful!
Mike
"None of us are as smart as all of us." -Martin Lee
Mike
hgfire
- motherboard: GatewayRS780
- processor: AMD Phenom II X4 810
- ram: 4GB
- Video Card: ATI Radeon HD 3200
- sound_card: Realtek HD audio
- Hard_Drive_Capacity: 1250.15
- Monitor/Display Make & Model: Samsung SyncMaster
Thank you for this solution. I hurriedly typed in a file path that was wrong by one letter and obviously I got the write-protected error.
Somethings in life are so simple yet I created my own frustration and problem.
Thank you lata
Thank you lata
- kdog509adam75+
- motherboard: Gateway H57M01
- processor: 2_93 gigahertz Intel Core I3 530
- ram: 6072 Megab
- Video Card: NVIDIA GeForce GTX 650 Ti
- Hard_Drive_Capacity: 2500 Gi
- Monitor/Display Make & Model: VIZ E280-B1 [Monitor] (27.7"vis)
- Corel programs: PSP 7.04, PSP 2021, VS PRO X4, VS 2020
OMG.... I was having the same trouble with Quick Time Movie files I was trying to edit in Video Studio 2021. I continued to get the error message "The file may be write protected" [15033:10:2]. I had noticed the Output Destination folder, for my system, was set to temp2/test. Temp2 is the folder I do all of my initial video editing in before moving the files to a different folder for final processing.
I had noticed the output destination folder was showing as temp2/test, but I just figured if the folder did not exist, VS would just create it. Not so. After I changed the output folder to simply temp2, VS compiled it with no problem. Sometimes the solution is so simple you just don't see it.
This rates as the Best Tip of the Week
fltsimguy
- ram: 32gigs
- Video Card: GTX1080ti
- Hard_Drive_Capacity: 72 TB
I just encountered this same issue. I spent half hour checking all the files and file folders to ensure they were not locked as "read-only" because that is what the error message seemed to indicate, then out of frustration checked here.
And yes the error was trying to save the output produced file to a folder that was actually deleted.
May I suggest that the software developers actually come up with a better error message, that is helpful because the current one is plainly misleading.
Bryan
Bryan
An easy solution to give a more meaningful messagefltsimguy wrote: ↑Fri Nov 19, 2021 2:09 am I just encountered this same issue. I spent half hour checking all the files and file folders to ensure they were not locked as "read-only" because that is what the error message seemed to indicate, then out of frustration checked here.
Bryan
Believe me! that has been requested for many years to the Corel development team.
I will be reporting this again in the next few days and bring their attention to this post.
Don’t hold your breath........
fltsimguy
- ram: 32gigs
Ah, great to hear thanks.
