Why Can't I Align a Raster Object?
PianoAl
operating_system: Windows 8.1
System_Drive: N
Post by PianoAl »
If I'm understanding correctly, I can align a vector object but not a raster object. Is that right? If so, is there any way to align a raster object without having to count pixels?
Thanks.
PSP V 16.2.0.20 64 on Windows 8.1
motherboard: Alienware M17xR4
ram: 6 GB
Hard_Drive_Capacity: 500GB
Corel programs: PSP: 8-2023
Re: Why Can't I Align a Raster Object?
Post by LeviFiction »
The normal procedure is select the raster object you wish to align, go to the menu Objects -> Align -> and select an option. I've used this many times to align images to the canvas or to other images. Evenly distributing three images across the canvas. That sort of thing.
You can't use the align options that show up on the tool options palette with the pick tool, but those are just visual representations of the commands in the Objects menu.
Cassel
ram: 16Gb
Corel programs: PSP 8 (JASC) to PSP 2023
Post by Cassel »
PIanoAl, what PSP version are you using? Aligning raster is only available in recent versions. For older versions, you can use the guides to snap the raster elements to them.
Cassel
https://scrapbookcampus.com
LindaSue
motherboard: Gigabyte
processor: 2.71GHz AMD Athlon II X2 215 processor
ram: 3 GB
Video Card: ATI Radeon HD 4350
sound_card: Realtek AC97 Audio [onboard]
Hard_Drive_Capacity: 1320 GB
Monitor/Display Make & Model: Asus MX279 HDMI 27-inch
Corel programs: Paint Shop Pro X2, X4, X6
Post by LindaSue »
You can align raster objects in X6, which is what Al is using.
Using Paint Shop Pro versions 5, 6, 7, 8, 9, 12, 14, 16
PianoAl
System_Drive: N
Post by PianoAl »
Sorry for the delay in responding.
I have version 16.2.0.20 x64. This is what it looks like when I right click on a raster layer:
That is, there is no option for align.
ram: 6 GB
Again, you have to use the Objects menu. Alignment was originally placed in PSP for vector objects only.
Later they allowed Alignment to be used for both vector objects and raster objects. But they did not place alignment options inside the context menu for raster objects. So, go to the Objects menu at the top of the program. Use the alignment options in there.
If you must have them inside the context menu then I recommend you use the Customize dialog and drag those options into the context menu.
Here is a video that outlines all of these steps - https://www.youtube.com/watch?v=yqbvYQ--DKY
1) View -> Customize
2) Click on the menu tab
3) Under the Context menu section from the drop-down select "Pick Tool Raster"
4) Open the Objects menu with the customize dialog still open
5) Ctrl + Click and Drag the Alignment option from Objects to the Pick tool Raster context menu
6) Drop it in the context menu anywhere you want
7) Close the Customize dialog
8) Save a copy of your workspace
PianoAl
System_Drive: N
Post by PianoAl »
Okay, perfect, thanks. Sorry I missed that the first time you mentioned it.
