Plenty of crashes
Bugs & Suggestions
pgman
operating_system: Linux
System_Drive: N/A
Plenty of crashes
Post by pgman »
I have 2.2 on an xUbuntu box and I'm browsing a small directory on a few hundred files. I'm selecting, deleting and renaming and it crashes all over:
Here are section (the log is 6136 lines) that I think are important
Code: Select all
0.0: I have SSE2
0.35: Bibble program arguments ("./AfterShotPro")
0.35: Loading plugins
0.144: AfterShot2 Pro New key used. 20
0.144: System locale: en_CA
0.226: AfterShot2 Pro New key used. 20
0.279: AfterShot2 Pro New key used. 20
0.282: AfterShot vers.: 2.2.0.29
0.282: Built on: "Sun Mar 22 2015"
0.282: Language: en
0.282: App Path: /opt/AfterShot2(64-bit)/bin/AfterShotPro
0.282: System Home: /opt/AfterShot2(64-bit)/supportfiles
0.282: User Home: /home/froggy/.AfterShot
0.282: Prefs Home: /home/froggy/.config/Corel/AfterShot Pro v2.conf
0.282: Platform:     Linux
0.282: Issue: "Ubuntu 14.04.2 LTS \n \l"
0.282: Kernel: "Linux version 3.13.0-53-generic (buildd@phianna) (gcc version 4.8.2 (Ubuntu 4.8.2-19ubuntu1) ) #89-Ubuntu SMP Wed May 20 10:34:39 UTC 2015"
0.282: Build Mode:   Release
0.282: Product Name: "AfterShot"
0.282: AfterShot2 Pro New key used. 20
0.282: Registered Version
0.283: AfterShot2 Pro New key used. 20
0.284: Initializing
0.284: Cpu Manager init: 8
0.284: ****	Making CLManager
0.348: Got 1 platforms
0.348: OpenCL is disabled in low mem mode
0.348: platform 0x29f21a0 "NVIDIA Corporation" OpenCL Version: "OpenCL 1.1 CUDA 6.0.1"
0.348: device: 0x273f140 "GeForce GTX 650 Ti"
0.391: ****** Device  "GeForce GTX 650 Ti" enabled
0.391: 	LDS size 49152
0.391: 	Compute units: 4
0.391: 	Freqency: 980
0.391: 	Max work items: 1024
0.391: 	Max work item sizes: 1024 1024 64
0.391: 	Device OpenCL Version: OpenCL 1.1 CUDA
0.391: 	Device OpenCL C Version: OpenCL C 1.1
0.391: 	Device OpenCL Extensions: cl_khr_byte_addressable_store cl_khr_icd cl_khr_gl_sharing cl_nv_compiler_options cl_nv_device_attribute_query cl_nv_pragma_unroll  cl_khr_global_int32_base_atomics cl_khr_global_int32_extended_atomics cl_khr_local_int32_base_atomics cl_khr_local_int32_extended_atomics cl_khr_fp64
0.391: 	Device Memory: true
0.391: 	Zero Copy: false
0.391: 	SVM: false
0.391: **************
0.392: 	Freqency: 980
0.392: 	Max work items: 1024
0.392: 	Max work item sizes: 1024 1024 64
0.392: 	Device OpenCL Version: OpenCL 1.1 CUDA
0.392: 	Device OpenCL C Version: OpenCL C 1.1
0.392: 	Device OpenCL Extensions: cl_khr_byte_addressable_store cl_khr_icd cl_khr_gl_sharing cl_nv_compiler_options cl_nv_device_attribute_query cl_nv_pragma_unroll  cl_khr_global_int32_base_atomics cl_khr_global_int32_extended_atomics cl_khr_local_int32_base_atomics cl_khr_local_int32_extended_atomics cl_khr_fp64
0.392: 	Device Memory: true
0.392: 	Zero Copy: false
0.392: 	SVM: false
0.392: **************
0.392: tileSize: 512
0.392: "MemTotal:       12275404 kB"
0.392: Memory:  3
0.392: ====================================================
0.392: Asset: 2147483647 purge
0.392: Heavy Asset: 2147483647 purge
0.392: NoiseEngine: 150 purge
0.392: NoiseEngine: 75 cache (50 min)
0.392: Histogram: 24 purge
0.392: Histogram: 12 cache (12 min)
0.393: PluginData: 9 purge
0.393: PluginData: 9 cache (8 min)
0.393: ====================================================
0.393: ImageMaster: 600 purge
0.393: ImageMaster: 300 cache (50 min)
0.393: NContainer: 2147483647 purge
0.393: Path: 2147483647 purge
0.393: Path: 2147483647 cache (2147483647 min)
0.393: RawData: 25165821 purge
0.393: UncompressedRawData: 9 purge
0.393: UncompressedRawData: 9 cache (8 min)
0.393: Version: 600 purge
0.393: Version: 300 cache (50 min)
0.393: PerfectlyClear: 6 purge
0.393: PerfectlyClear: 4 cache (4 min)
0.393: TileStack: 24 purge
0.393: TileStack: 12 cache (12 min)
0.393: StackTile: 3000 purge
0.393: Created 626 buffers of 857472
0.474: FALLBACK to 1252 tiles
0.475: ====================================================
0.475: BImageTile: 1800 purge
0.475: BTiledImage: 2147483647 purge
0.475: RegionImageTile: 3000 purge
0.475: Allocate Asset manager
0.476: Option group -  ""  - already contains an option with name -  "TIFFTAG_AFMODE"
0.476:   Option was not registered.
0.476: Option group -  ""  - already contains an option with name -  "TIFFTAG_FLASHMODE"
0.476: Globals: systemhome /opt/AfterShot2(64-bit)/supportfiles
0.476: Globals: userhome /home/froggy/.AfterShot
0.476:
====================  Plugins  =====================
      Name:
Identifier:
   Version: 1.0.0
      Path:
      Name: Black and White
Identifier: com.corel.BlackAndWhite
   Version: 1.0.0
      Path: <System Home>/plugins/Black and White.afplugin
Identifier: com.corel.equalizer
   Version: 1.0.5
      Path: <System Home>/plugins/Equalizer.afplugin
0.529: LensDB  inserting camera Panasonic Micro 4/3 DMC-GF3 failed
0.547: /home/froggy/.AfterShot/bibbledebug
0.549: AfterShot2 Pro New key used. 20
0.551: Creating main window
0.552: AfterShot2 Pro New key used. 20
0.553: Starting Catalog Manager
3.902: New Io Asset Mananager
4.38:   DB 0 at version 20
4.38: Locking catalog:  "/home/froggy/.AfterShot/cache"
4.38: Locking for station:  "{d81f7c06-eebd-4c69-9de5-7a11ce6a3ffa}"
4.38: "/home/froggy/.AfterShot/cache/aftershot.lock" Previous lock:  "{d81f7c06-eebd-4c69-9de5-7a11ce6a3ffa}"
4.38: Opening DB "/home/froggy/.AfterShot/cache"
4.39:   DB 1 is already up to date
4.40: AfterShot2 Pro New key used. 20
4.42: Scheduled Cache Cleaning
4.44: CacheReducer removed 0 versions due to age older than QDateTime("2015-05-16 20:22:53.856 PDT Qt::LocalTime")
4.44:   Starting cache cleanup
4.44:   purging history for 170 versions
4.351:   Finished cache cleanup
4.351: Locking catalog:  "/home/froggy/Pictures/AfterShot Catalogs/AfterShot Catalog 2014"
4.351: Locking for station:  "{d81f7c06-eebd-4c69-9de5-7a11ce6a3ffa}"
4.351: "/home/froggy/Pictures/AfterShot Catalogs/AfterShot Catalog 2014/aftershot.lock" Previous lock:  "{d81f7c06-eebd-4c69-9de5-7a11ce6a3ffa}"
4.351: Opening DB "/home/froggy/Pictures/AfterShot Catalogs/AfterShot Catalog 2014"
4.352:   DB 2 is already up to date
4.473: AfterShot2 Pro New key used. 20
4.475: Starting Asset Manager
4.476: AfterShot2 Pro New key used. 20
4.477: Starting Memory Manager
4.540: AfterShot2 Pro New key used. 20
4.555: AfterShot2 Pro New key used. 20
4.559: AfterShot2 Pro New key used. 20
4.563: AfterShot2 Pro New key used. 20
4.567: AfterShot2 Pro New key used. 20
4.571: AfterShot2 Pro New key used. 20
4.574: AfterShot2 Pro New key used. 20
4.578: AfterShot2 Pro New key used. 20
4.581: AfterShot2 Pro New key used. 20
4.586: AfterShot2 Pro New key used. 20
4.595: AfterShot2 Pro New key used. 20
4.771: Trying to set copyset shortcut  "Ctrl+8"  for  "Color Correction"
4.771: Trying to set copyset shortcut  "Ctrl+9"  for  "Exposure"
4.771: Trying to set copyset shortcut  "Ctrl+3"  for  "GPS Settings"
4.771: Trying to set copyset shortcut  "Ctrl+4"  for  "IPTC Photographer's Details"
4.771: Trying to set copyset shortcut  "Ctrl+1"  for  "Metadata and IPTC"
4.772: Trying to set copyset shortcut  "Ctrl+2"  for  "Metadata, IPTC, and GPS"
4.772: Registering AfterShot plugin...  "BibbleBuiltin"
4.772: Registering AfterShot plugin...  "Equalizer"
4.772: Registering AfterShot plugin...  "BlackAndWhite"
4.772: 0 :  "UncompressedRawData"
4.772: 1 :  "RawNoise"
4.772: 2 :  "Demosaic"
4.772: 3 :  "TiffSrc"
4.772: 4 :  "JpegSrc"
4.772: 5 :  "Mip"
4.772: 6 :  "PreScalingFilter"
4.772: 7 :  "CameraRgbToWorkingspace_Rendered"
4.772: 8 :  "CloneLayer"
4.772: 9 :  "HealRendererFilter"
4.772: 10 :  "Highlights"
4.772: 11 :  "SpatialDistortion"
4.772: 12 :  "Positive Vignette"
4.773: 13 :  "Mirror"
4.773: 14 :  "Crop"
4.773: 15 :  "WhiteBalance"
4.773: 16 :  "AutoLevel"
4.773: 17 :  "Exposure"
4.773: 18 :  "FillLight"
4.773: 19 :  "USM"
4.773: 20 :  "CameraRgbToWorkingspace_Raw"
4.773: 21 :  "PerfectlyClear"
4.773: 22 :  "Sharpen"
4.773: 23 :  "Invert"
4.773: 24 :  "Color"
4.773: 25 :  "SelectiveColor"
4.773: 26 :  "EqualizerFilter"
4.773: 27 :  "RgbToLab"
4.773: 28 :  "LabToRgb"
4.773: 29 :  "BlackAndWhiteFilter"
4.773: 30 :  "Curves"
4.773: 31 :  "Negative Vignette"
4.773: 32 :  "WorkingToMonitor"
4.773: 33 :  "AthentechPFCNoise"
4.773: 34 :  "RedeyeBuf"
4.773: 35 :  "Redeye"
4.773: 0 :  "VersionStackSrc"
4.773: 1 :  "PostImage"
4.773: 2 :  "AthentechPFCNoise"
4.773: 3 :  "RedeyeBuf"
4.773: 4 :  "Redeye"
4.773: 0 :  "JpegSrc"
4.773: 1 :  "Mip"
4.773: 2 :  "WorkingToMonitor"
4.809: "/opt/AfterShot2(64-bit)/supportfiles/tools//"
6.41: AfterShot2 Pro New key used. 20
6.43: Ready
6.189: QSslSocket: cannot resolve SSLv2_client_method
6.189: QSslSocket: cannot resolve SSLv2_server_method
6.316: QObject::connect: No such signal QAction::trigger(bool)
6.317: QObject::connect:  (receiver name: 'Directory View')
6.355: Initializing file system view...
6.355: File: s: 28
6.361: File system view initialized.
6.362: Container __CATALOG_ROOT__/assets
6.409: No custom slideshow settings found
7.252: MultiImageView::doCursor() Invalid cursor mode
7.257: File: s: 3
7.258: File: s: 50
7.262: File: s: 26
7.268: File: s: 268
7.277: ContainerAsset could not get path by ID
7.279: Container __CATALOG_ROOT__/assets
7.280: Container __CATALOG_ROOT__/assets/home
7.281: Container __CATALOG_ROOT__/assets/home/froggy
7.284: Container __CATALOG_ROOT__/assets/home/froggy/photos
7.285: set sort order ascending
7.285: Container __CATALOG_ROOT__/assets/home/froggy/photos/70d
7.290: Opening DB "/home/froggy/.AfterShot/cache"
7.475: viewmode: 1
7.707: Starting import with settings :  "<x:xmpmeta xmlns:x="adobe:ns:meta/" x:xmptk="XMP Core 4.4.0">
 <rdf:RDF xmlns:rdf="http://www.w3.org/1999/02/22-rdf-syntax-ns#">
  <rdf:Description rdf:about=""
    xmlns:bibp="http://www.bibblelabs.com/BibblePrivate/5.0/"
   bibp:MoveCopy="2"
   bibp:LibraryLoc=""
   bibp:LibraryID="1044"
   bibp:LibraryUuid="{0b7c166d-67e9-4082-abd6-8258f3ae3345}"
   bibp:Organize="0"
   bibp:FolderTemplate=""
   bibp:Recurse="false"
   bibp:RenameOn="false"
   bibp:FileTemplate=""
   bibp:ImportPath="/home/froggy/photos/70d"
   bibp:KeywordList=""
   bibp:FolderFilter=""
   bibp:QueueName=""
   bibp:QueueType="0"
   bibp:QueueOnlyNewFiles="false"
   bibp:JobName=""
   bibp:PresetList=""/>
 </rdf:RDF>
</x:xmpmeta>
7.708: Adding master versions
7.899: Adding master versions
7.900: Scanning file  "/home/froggy/photos/70d/construction-vancouver-20140530-1556.cr2"
7.903: Scanning file  "/home/froggy/photos/70d/construction-vancouver-20140530-1603.cr2"
7.904: Scanning file  "/home/froggy/photos/70d/construction-vancouver-20140530-1608.cr2"
7.904: Scanning file  "/home/froggy/photos/70d/construction-vancouver-20140531-1923.cr2"
7.905: Scanning file  "/home/froggy/photos/70d/construction-vancouver-20140531-1928.cr2"
then plenty more and it dies on
Code: Select all
145.369: QPainter::setBrush: Painter not active
145.369: QPainter::setOpacity: Painter not active
145.369: QPainter::setPen: Painter not active
145.369: QPainter::restore: Unbalanced save/restore
I do not have any image from a Micro4/3 and/or Panasonic
OpenCL is disabled in AftershotPro through the preferences
I have no plugin installed (these are the ASP installed)
The "QPainter::restore: Unbalanced save/restore" happens for every image in the log
Any suggestion on how I can fix my problem?
Syv
jlouder
System_Drive: N/A
processor: Intel i5-2430M
Hard_Drive_Capacity: 800GB
Re: Plenty of crashes
Post by jlouder »
I am also having crashes, running 32-bit on Ubuntu 15.04. I may be having the same problem as you, my crashes happen only when I try to drag and drop a photo. I normally drag-and-drop to the Output window, and I've had to stop doing that (using right-click instead to send to a batch).
My log looks similar to yours, with the last message being the "unbalanced save/restore." I capture a core file from the crash (it was a segmentation fault) and grabbed this stack trace, in case that is helpful to anyone at Corel.
Code: Select all
Core was generated by `./AfterShotPro'.
Program terminated with signal SIGSEGV, Segmentation fault.
#0  0xaf23b1b9 in ?? () from /opt/AfterShot2/lib/plugins/platforms/libqxcb.so
(gdb) bt
#1  0xaf23b437 in ?? () from /opt/AfterShot2/lib/plugins/platforms/libqxcb.so
#2  0xaf1db1fb in ?? () from /opt/AfterShot2/lib/plugins/platforms/libqxcb.so
#3  0xaf1ca164 in ?? () from /opt/AfterShot2/lib/plugins/platforms/libqxcb.so
#4  0xb3c695a0 in QWindowPrivate::create(bool) () from /opt/AfterShot2/lib/libQt5Gui.so.5
#5  0xb3c697c6 in QWindow::create() () from /opt/AfterShot2/lib/libQt5Gui.so.5
#6  0xb3c55a05 in ?? () from /opt/AfterShot2/lib/libQt5Gui.so.5
#7  0xb3c5622e in QBasicDrag::startDrag() () from /opt/AfterShot2/lib/libQt5Gui.so.5
#8  0xaf1d419f in ?? () from /opt/AfterShot2/lib/plugins/platforms/libqxcb.so
#9  0xb3c56a06 in QBasicDrag::drag(QDrag*) () from /opt/AfterShot2/lib/libQt5Gui.so.5
#10 0xb3c729eb in QDragManager::drag(QDrag*) () from /opt/AfterShot2/lib/libQt5Gui.so.5
#11 0xb3c71c9f in QDrag::exec(QFlags<Qt::DropAction>, Qt::DropAction) () from /opt/AfterShot2/lib/libQt5Gui.so.5
#12 0xb3c71d3b in QDrag::exec(QFlags<Qt::DropAction>) () from /opt/AfterShot2/lib/libQt5Gui.so.5
#13 0x0847945a in ThumbItem::mouseMoveEvent(QGraphicsSceneMouseEvent*) ()
#14 0xb45a2757 in QGraphicsItem::sceneEvent(QEvent*) () from /opt/AfterShot2/lib/libQt5Widgets.so.5
#15 0xb45d41ae in ?? () from /opt/AfterShot2/lib/libQt5Widgets.so.5
#16 0xb45d4d44 in ?? () from /opt/AfterShot2/lib/libQt5Widgets.so.5
#17 0xb45d5933 in QGraphicsScene::mouseMoveEvent(QGraphicsSceneMouseEvent*) () from /opt/AfterShot2/lib/libQt5Widgets.so.5
#18 0xb45e4ae7 in QGraphicsScene::event(QEvent*) () from /opt/AfterShot2/lib/libQt5Widgets.so.5
#19 0xb4232c14 in QApplicationPrivate::notify_helper(QObject*, QEvent*) () from /opt/AfterShot2/lib/libQt5Widgets.so.5
#20 0xb4236777 in QApplication::notify(QObject*, QEvent*) () from /opt/AfterShot2/lib/libQt5Widgets.so.5
#21 0xb3938b0e in QCoreApplication::notifyInternal(QObject*, QEvent*) () from /opt/AfterShot2/lib/libQt5Core.so.5
This isn't the entire stack trace, it was about 55 calls deep. I am still trying to do research on my own, but I'm not sure how far I will get -- the crash is happening inside AfterShot Pro libraries, not system libraries, and the library with the call that's crashing (libqxcb.so) is stripped of debugging symbols so I can't see even the names of the functions it's calling.
My plugins folder is empty, so as far as I know I am not running any plugins, that was my first thought when I saw the crash.
Is anyone else seeing something like this? Or, if you are crashing on Linux, if you need help capturing a core file and getting a stack trace like this, I can help. Maybe we are all crashing in the same spot.
dFlyer
System_Drive: N/A
Post by dFlyer »
Same problem with 2.2 on Ubuntu 14.04.2. Drag and dropping to output crashes system. Currently have down graded to 2.1 which seems to be still working good. Also has all the plug-ins I use. Will try 2.2 again when the plug-ins catch up.
Thanks.
Gary Garibaldi
Linux since 96
Sony a700
Sony a100
Caio S
System_Drive: N/A
processor: Intel i7-4700M
ram: 12 GB
Video Card: GTX 765M
Hard_Drive_Capacity: 1 TB
Post by Caio S »
I'm having the same problem here too. Every time I try to drag a photo preview, the program just crashes with a segmentation fault. I'm running ASP 2.2.0.29 on Ubuntu 14.04 and 15.04, both 64 bits.
Is there a way to move photos between collection folders without using drag & drop?
Caio S
System_Drive: N/A
ram: 12 GB
Post by Caio S »
I'm uploading the program stack when it crashes. The segmentation fault occurs when we try to drag any preview.
Cheers
stack.log
Stack trace
(23.44 KiB) Downloaded 339 times
dFlyer
System_Drive: N/A
Post by dFlyer »
dFlyer wrote:Same problem with 2.2 on Ubuntu 14.04.2. Drag and dropping to output crashes system. Currently have down graded to 2.1 which seems to be still working good. Also has all the plug-ins I use. Will try 2.2 again when the plug-ins catch up.
Just upgraded to ASP-2.2.1. Still crashing with drag and drop. Attached is the ASP.log. Again down graded to 2.1 which is still working good and still has all the plugins I use.
AfterShotPro.log
(34.99 KiB) Downloaded 303 times
Thanks.
Gary Garibaldi
Linux since 96
Sony a700
Sony a100
fams
System_Drive: N/A
motherboard: Gigabyte GA-Z77-DS3H
processor: Intel i5-3570K
Video Card: Onboard
sound_card: Onboard
Hard_Drive_Capacity: 1.5TB
Monitor/Display Make & Model: Eizo 23"
Corel programs: Aftershot Pro
Post by fams »
Ubuntu 15.04 x64, Aftershot Pro x64 2.2.1.64, no plugins.
Same here, no drag'n drop possible without crash.
Deleting more than three master versions crashes system too.
imhotep
System_Drive: N/A
Post by imhotep »
I have the same issue. Even the Keywordmanager crashes if you try to drag a keyword from the list to the keywordset.
It probably has nothing to do with photos.
Karsten
