Unable to start AfterShotPro2
BrosiusPhotos
operating_system: Linux
System_Drive: N/A
Post by BrosiusPhotos »
I recently upgraded to ASP2 2.2.0.29 32-bit and 64-bit. I use both because I like to use plugins which are only available for 32-bit but sometimes I want the added benefit of 64-bit. I have been running like this for years until the latest version. Now when I try to start the 32-bit version, I get this message:
Install Path: /opt/AfterShot2
LD_PATH: /opt/AfterShot2/lib:
XLIB_SKIP_ARGB_VISUALS: 1
./AfterShotPro: error while loading shared libraries: libxslt.so.1: cannot open shared object file: No such file or directory
Sure enough, I do not have libxslt.so.1 in /opt/AfterShot2/lib. However, I am able to start the 64-bit version and that file doesn't exist in "/opt/AfterShot2(64-bit)/lib" either. I tried re-downloading the 32-bit version to no avail.
Can anyone make a suggestion about how I can resolve this? Without the 32-bit version, I can't use my plugin and it is not yet available for 64-bit.
uname -a
Linux den 3.13.0-52-generic #86-Ubuntu SMP Mon May 4 04:32:59 UTC 2015 x86_64 x86_64 x86_64 GNU/Linux
Thank you.
BrosiusPhotos
System_Drive: N/A
Re: Unable to start AfterShotPro2
I was able to get it running by installing the following software:
libxslt1.1:i386
libgstreamer0.10-0:i386
libgstreamer-plugins-base0.10-0:i386
So obviously something was missing with the 32-bit version.
