Installation problem with AfterShot Pro 2.2.0.29
frisbee
- Corel programs: AfterShotPro 2
I just installed the update AfterShot Pro 2.2.0.29.
On my desktop (Windows 8.1, 64 bit), everything went fine, program working perfectly.
On my Dell laptop (Windows 8.1, 64 bit), the program completed installation, but when I run it, it locks at the splash screen with the message "AfterShot Pro has stopped working."
On my Dell tablet (Windows 8.1, 32 bit), I have the same problem. Locks at the splash screen with message "AfterShot Pro has stopped working."
On the laptop and tablet, I returned to AfterShot Pro 2.1.12.10, which runs fine.
I assume this is a bug, that will be corrected in the next release.
Any information?
Any information?
afx
- System_Drive: N/A
- Video Card: FirePro 4900
Re: Installation problem with AfterShot Pro 2.2.0.29
How should anyone know?
You don't provide any details at all.
What is in the logile?
cheers
afx
cheers
afx
frisbee
The installation went fine. So no log file.
But the program gives an error message when starting.
Just curious if anyone else had this problem.
Thanks.
Thanks.
afx
- System_Drive: N/A
AS writes a log file every time it starts....frisbee wrote:The installation went fine. So no log file.
cheers
afx
frisbee
Here is information from the log files generated by AfterShot Pro 2.2.0.29, on my Dell tablet. Any help appreciated.
The description for Event ID 1 from source DptfPolicyLpmService cannot be found. Either the component that raises this event is not installed on your local computer or the installation is corrupted. You can install or repair the component on the local computer.
If the event originated on another computer, the display information had to be saved with the event.
The following information was included with the event:
ServiceMainThread: App specific mode was turned off, but timer was not running.
Faulting application name: AfterShotPro.exe, version: 6.0.0.3, time stamp: 0x550eac83
Faulting module name: ntdll.dll, version: 6.3.9600.17736, time stamp: 0x550f42bd
Exception code: 0xc0000374
Fault offset: 0x000d0982
Faulting process id: 0x668
Faulting application start time: 0x01d0942ef8cce312
Faulting application path: C:\Program Files\Corel\Corel AfterShot 2\build\AfterShotPro.exe
Faulting module path: C:\Windows\SYSTEM32\ntdll.dll
Report Id: 3c9cb3e7-0022-11e5-9794-88124e88b46c
Faulting package full name:
Faulting package-relative application ID:
afx
- System_Drive: N/A
This is not the AS log.. Check in your AS user directory.
cheers
afx
cheers
afx
frisbee
How's this?
I navigated to C:\Users\Ron\AppData\Local\Corel\AfterShot Pro where AfterShotPro.log is located.
File attached.
Ron
File attached.
Ron
- Attachments
- AfterShotPro.log
- (10.8 KiB) Downloaded 499 times
afx
- System_Drive: N/A
Right file, but unfortunately nothing really exciting.
Two things you could try:
Rename "C:/Users/Ron/AppData/Local/Corel/AfterShot Pro" and then start and see whether it helps.
And disable OpenCL (no idea (and too far from the windows box to check) where you can hack that on Windows, probably in the registry somewhere under "\HKEY_CURRENT_USER\Software\Corel\AfterShot Pro v2") and see whether that changes anything.
cheers
afx
cheers
afx
dstrong43
- motherboard: Dell Inc. 088DT1 A01
- processor: intel i3-4150 CPU 3.5 GHz
- Video Card: Intel HD Graphics 4400
- sound_card: DELL S2240L Display Audio
- Hard_Drive_Capacity: 3.18168 TB
- Monitor/Display Make & Model: DELL S2240L and DELL IN1910N
- Corel programs: CorelDraw;Paintshop;AfterShot
I am experiencing a similar problem with my 64-bit Dell desktop. In my most recent contact with Corel, the tech indicated that:
1. It is a known issue
2. my case seems to be related to the graphics adapter, the Intel HD Graphics 4400
3. the tech did not succeed in downloading a corrected adapter driver from Intel and instructed me to check with Dell. When I did, the "latest" driver was, according to Windows 10, an earlier driver than the one that was installed, and I did not download it at that time.
4. the tech then referred my case to "the engineers," without any estimate for an ETA.
Has anyone else succeeded in running Aftershot Pro with the HD Graphics 4400 adapter? Is anyone else experiencing the same problem?
Alex Brazeau
Hi dstrong, Do you have a case number I can reference when I flag this with the dev team? Thanks.dstrong43 wrote:Has anyone else succeeded in running Aftershot Pro with the HD Graphics 4400 adapter? Is anyone else experiencing the same problem?
Martin5000
- motherboard: Gateway TBGM01
- processor: 2.67 gigahertz Intel Core i7 920
- ram: 12280 MB
- Video Card: GeForce GTX 750
- Hard_Drive_Capacity: 984.47 GB
- Monitor/Display Make & Model: Hanns.G iH282
- Corel programs: AfterShot Pro3
Did you ever get this resolved?
I had AfterShot 2 Pro 64 bit working on my Asus ZenBook with Win10 64bit but with several plugins only available as 32bit, I thought I would install that version instead. Total Fail. It installs but as soon as I try to run it, I get the fail message too.
In my case the GPU is the Intel HD Graphics 5300. Do I have to go back to 64 bit?
The driver is 20.19.15.4331 dated 2015-11-18
Martin5000
- ram: 12280 MB
False alarm here. Turns out that there must have been some registry values interfering with the 32 bit install, even after deleting the 64 bit version. After a CCLean session, the 32 bit version installed and runs.
