After installing the Nostalgia Film Simulation plugin with "Installation Successfull" message and restarting Corel Aftershot as prompted, the plugin does not shows up in plugins ...
Any idea whats wrong?
Plugin after installing does not shows up ...
afx
- System_Drive: N/A
- Video Card: FirePro 4900
Re: Plugin after installing does not shows up ...
Nostalgia is basically dead...
No 64bit version and no suort for AS 2.2 onwards.
cheers
afx
cheers
afx
i have also the 32 bit version of AS installed on the same computer and the plugin i installed in that 32 AS...
The message says installed successfully ...
afx
- System_Drive: N/A
The install message just tells you the files where copied into the appropriate place.
What Version of AS are you running?
cheers
afx
cheers
afx
thanx for your explanation.
I use version 2.2.0.29
afx
- System_Drive: N/A
As I wrote above, Nostalgia is dead, its author refuses to update the plugin to work with 2.2.
cheers
afx
cheers
afx
