Whenever I try to burn a disc (DVD or CD), I get the error
The target device might have some problems. Please try again later or reboot.
(5213)
When I click the OK buton, I get a second message
Failed to record data to the disc.
Error: SAO-2236-SPTI-2A-00-0000057. The parameter is incorrect.
I get the same error when I create an image file first and then try to burn it using the Ulead VCD/DVD Disc Image Recorder.
The DVD is functioning fine, as I can write discs from other applications (e.g. the tape-to-VCD application that came with the Sony camera)
Any ideas?
TIA,
Luc
Error (5213) while burning disc
Do you happen to have the Nero InCD application installed (it's part of the general Nero suite)? Sometimes, that -- or similar packet-writing programs -- sometimes takes control of the burner and won't allow other programs to use it. If you do have InCD installed, try uninstalling it and then burning your disc.
Luc Kumps
Thanks for your quick response, Ken!Ken Berry wrote:Do you happen to have the Nero InCD application installed (it's part of the general Nero suite)? Sometimes, that -- or similar packet-writing programs -- sometimes takes control of the burner and won't allow other programs to use it. If you do have InCD installed, try uninstalling it and then burning your disc.
No, I don't have Nero installed. The Sony camcorder software is installed and is able to burn a disc.
Would 5312 and "parameter is incorrect" point into the direction of disc-sharing problems?
Luc
