Crashing 2.2
pgman
operating_system: Linux
System_Drive: N/A
Crashing 2.2
Post by pgman »
I have 2.2 on Ubuntu 14.04 and it crashes.
I have the following warning:
Code: Select all
0.45: Warning: slow tiles used because plugin is not white listed:  "zChannelMixer"
0.45: Warning: slow tiles used because plugin is not white listed:  "Zone"
Should I disable them?
Code: Select all
0.200: OpenCL is disabled in low mem mode
low mem? I have 12 gig of ram/ x64?
Here is the full .aftershot log
Code: Select all
0.0: I have SSE2
0.43: Bibble program arguments ("./AfterShotPro")
0.43: Loading plugins
0.110: AfterShot2 Pro New key used. 20
0.110: System locale: en_CA
0.150: AfterShot2 Pro New key used. 20
0.195: AfterShot2 Pro New key used. 20
0.197: AfterShot vers.: 2.2.0.29
0.197: Built on: "Sun Mar 22 2015"
0.197: Language: en
0.197: App Path: /opt/AfterShot2(64-bit)/bin/AfterShotPro
0.197: System Home: /opt/AfterShot2(64-bit)/supportfiles
0.197: User Home: /home/froggy/.AfterShot
0.197: Prefs Home: /home/froggy/.config/Corel/AfterShot Pro v2.conf
0.197: Platform:     Linux
0.197: Issue: "Ubuntu 14.04.2 LTS \n \l"
0.197: Kernel: "Linux version 3.13.0-52-generic (buildd@aatxe) (gcc version 4.8.2 (Ubuntu 4.8.2-19ubuntu1) ) #85-Ubuntu SMP Wed Apr 29 16:44:17 UTC 2015"
0.197: Build Mode:   Release
0.198: Product Name: "AfterShot"
0.198: AfterShot2 Pro New key used. 20
0.198: Registered Version
0.199: AfterShot2 Pro New key used. 20
0.200: Initializing
0.200: Cpu Manager init: 8
0.200: ****	Making CLManager
0.200: Got 0 platforms
0.200: "Could not select an OpenCL platform"
0.200: ****	CLManager not initialized
0.200: tileSize: 256
0.201: "MemTotal:       12275412 kB"
0.201: Memory:  3
0.201: ====================================================
0.201: Asset: 2147483647 purge
0.201: Heavy Asset: 2147483647 purge
0.201: NoiseEngine: 150 purge
0.201: NoiseEngine: 75 cache (50 min)
0.201: Histogram: 24 purge
0.201: Histogram: 12 cache (12 min)
0.201: PluginData: 9 purge
0.201: PluginData: 9 cache (8 min)
0.201: ImageMaster: 600 purge
0.201: ImageMaster: 300 cache (50 min)
0.201: NContainer: 2147483647 purge
0.201: Path: 2147483647 purge
0.201: Path: 2147483647 cache (2147483647 min)
0.201: RawData: 25165821 purge
0.201: UncompressedRawData: 9 purge
0.201: UncompressedRawData: 9 cache (8 min)
0.201: Version: 600 purge
0.201: Version: 300 cache (50 min)
0.202: ====================================================
0.202: PerfectlyClear: 6 purge
0.202: PerfectlyClear: 4 cache (4 min)
0.202: TileStack: 24 purge
0.202: TileStack: 12 cache (12 min)
0.202: StackTile: 3000 purge
0.202: Created 626 buffers of 857472
0.286: FALLBACK to 1252 tiles
0.286: ====================================================
0.286: BImageTile: 1800 purge
0.287: BTiledImage: 2147483647 purge
0.287: ====================================================
0.287: RegionImageTile: 3000 purge
0.287: Allocate Asset manager
0.288: Option group -  ""  - already contains an option with name -  "TIFFTAG_AFMODE"
0.288:   Option was not registered.
0.288: Option group -  ""  - already contains an option with name -  "TIFFTAG_FLASHMODE"
0.288: Globals: systemhome /opt/AfterShot2(64-bit)/supportfiles
0.288: Globals: userhome /home/froggy/.AfterShot
0.288:
====================  Plugins  =====================
      Name:
Identifier:
   Version: 1.0.0
      Path:
Identifier: com.ferdinand-paris.bez
   Version: 1.0.1
      Path: <User Home>/Plugins (64-bit)/Bez64.afplugin
Identifier: Grid-64
   Version: 1.0.0
      Path: <User Home>/Plugins (64-bit)/Grid-64.afplugin
Identifier: com.ferdinand-paris.mix3
   Version: 1.0.1
      Path: <User Home>/Plugins (64-bit)/Mix364.afplugin
Identifier: tin.tin.zchannelmixer
   Version: 3.1.0
      Path: <User Home>/Plugins (64-bit)/zChannelMixer64.afplugin
Identifier: Zone-64
   Version: 1.0.1
      Path: <User Home>/Plugins (64-bit)/Zone-64.afplugin
      Name: Black and White
Identifier: com.corel.BlackAndWhite
   Version: 1.0.0
      Path: <System Home>/plugins/Black and White.afplugin
Identifier: com.corel.equalizer
   Version: 1.0.5
      Path: <System Home>/plugins/Equalizer.afplugin
0.343: LensDB  inserting camera Panasonic Micro 4/3 DMC-GF3 failed
0.344: /home/froggy/.AfterShot/bibbledebug
0.345: AfterShot2 Pro New key used. 20
0.347: Creating main window
0.348: AfterShot2 Pro New key used. 20
0.350: Starting Catalog Manager
7.883: New Io Asset Mananager
8.356:   DB 0 at version 20
8.356: removing old cache folder "/home/froggy/.AfterShot/cache"
8.356: removing old cache folder "/home/froggy/.AfterShot/cache/assets"
8.356: removing old cache folder "/home/froggy/.AfterShot/cache/assets/home"
8.356: removing old cache folder "/home/froggy/.AfterShot/cache/assets/home/froggy"
8.356: removing old cache folder "/home/froggy/.AfterShot/cache/assets/home/froggy/photos"
8.356: removing old cache folder "/home/froggy/.AfterShot/cache/assets/home/froggy/photos/7dmk2"
8.398: Locking catalog:  "/home/froggy/.AfterShot/cache"
8.398: Locking for station:  "{d81f7c06-eebd-4c69-9de5-7a11ce6a3ffa}"
8.551: Opening DB "/home/froggy/.AfterShot/cache"
8.628: AfterShot2 Pro New key used. 20
8.630: Scheduled Cache Cleaning
8.631: CacheReducer removed 0 versions due to age older than QDateTime("2015-05-02 09:47:49.573 PDT Qt::LocalTime")
8.631: "Created new cache database at: /home/froggy/.AfterShot/cache"
9.11:   Starting cache cleanup
9.12:   Finished cache cleanup
9.12: Locking catalog:  "/home/froggy/Pictures/AfterShot Catalogs/AfterShot Catalog 2014"
9.12: Locking for station:  "{d81f7c06-eebd-4c69-9de5-7a11ce6a3ffa}"
9.12: "/home/froggy/Pictures/AfterShot Catalogs/AfterShot Catalog 2014/aftershot.lock" Previous lock:  "{d81f7c06-eebd-4c69-9de5-7a11ce6a3ffa}"
9.12: Opening DB "/home/froggy/Pictures/AfterShot Catalogs/AfterShot Catalog 2014"
9.13:   DB 2 is already up to date
9.130: AfterShot2 Pro New key used. 20
9.131: Starting Asset Manager
9.132: AfterShot2 Pro New key used. 20
9.133: Starting Memory Manager
9.197: AfterShot2 Pro New key used. 20
9.211: AfterShot2 Pro New key used. 20
9.215: AfterShot2 Pro New key used. 20
9.218: AfterShot2 Pro New key used. 20
9.222: AfterShot2 Pro New key used. 20
9.226: AfterShot2 Pro New key used. 20
9.229: AfterShot2 Pro New key used. 20
9.233: AfterShot2 Pro New key used. 20
9.235: AfterShot2 Pro New key used. 20
9.239: AfterShot2 Pro New key used. 20
9.249: AfterShot2 Pro New key used. 20
9.427: Trying to set copyset shortcut  "Ctrl+8"  for  "Color Correction"
9.427: Trying to set copyset shortcut  "Ctrl+9"  for  "Exposure"
9.427: Trying to set copyset shortcut  "Ctrl+3"  for  "GPS Settings"
9.427: Trying to set copyset shortcut  "Ctrl+4"  for  "IPTC Photographer's Details"
9.427: Trying to set copyset shortcut  "Ctrl+1"  for  "Metadata and IPTC"
9.427: Trying to set copyset shortcut  "Ctrl+2"  for  "Metadata, IPTC, and GPS"
9.427: Registering AfterShot plugin...  "BibbleBuiltin"
9.427: Registering AfterShot plugin...  "Grid"
9.428: Registering AfterShot plugin...  "Equalizer"
9.428: Registering AfterShot plugin...  "BlackAndWhite"
9.428: Registering AfterShot plugin...  "Zone"
9.428: Registering AfterShot plugin...  "zChannelMixer"
9.428: Registering AfterShot plugin...  "Mix3"
9.428: Successfully registered  "Mix3FilterEARLY"  before RgbToLab and  "Mix3FilterLATE"  before Curves using priority  800
9.428: Registering AfterShot plugin...  "Bez"
9.428: Successfully registered  "BezFilterEARLY"  before RgbToLab and  "BezFilterLATE"  before Curves using priority  900
9.428: 0 :  "UncompressedRawData"
9.428: 1 :  "RawNoise"
9.428: 2 :  "Demosaic"
9.428: 3 :  "TiffSrc"
9.428: 4 :  "JpegSrc"
9.428: 5 :  "Mip"
9.428: 6 :  "PreScalingFilter"
9.428: 7 :  "CameraRgbToWorkingspace_Rendered"
9.428: 8 :  "CloneLayer"
9.428: 9 :  "HealRendererFilter"
9.428: 10 :  "Highlights"
9.428: 11 :  "SpatialDistortion"
9.428: 12 :  "Positive Vignette"
9.428: 13 :  "Mirror"
9.428: 14 :  "Crop"
9.428: 15 :  "WhiteBalance"
9.428: 16 :  "AutoLevel"
9.428: 17 :  "Exposure"
9.429: 18 :  "FillLight"
9.429: 19 :  "USM"
9.429: 20 :  "CameraRgbToWorkingspace_Raw"
9.429: 21 :  "PerfectlyClear"
9.429: 22 :  "Sharpen"
9.429: 23 :  "Invert"
9.429: 24 :  "Color"
9.429: 25 :  "SelectiveColor"
9.429: 26 :  "EqualizerFilter"
9.429: 27 :  "Mix3FilterEARLY"
9.429: 28 :  "BezFilterEARLY"
9.429: 29 :  "RgbToLab"
9.429: 30 :  "LabToRgb"
9.429: 31 :  "BlackAndWhiteFilter"
9.429: 32 :  "zChannelMixerFilter"
9.429: 33 :  "Mix3FilterLATE"
9.429: 34 :  "BezFilterLATE"
9.429: 35 :  "Curves"
9.429: 36 :  "Negative Vignette"
9.429: 37 :  "ZoneFilter"
9.429: 38 :  "GridFilter"
9.429: 39 :  "WorkingToMonitor"
9.429: 40 :  "AthentechPFCNoise"
9.429: 41 :  "RedeyeBuf"
9.429: 42 :  "Redeye"
9.429: 0 :  "VersionStackSrc"
9.429: 1 :  "PostImage"
9.429: 2 :  "AthentechPFCNoise"
9.429: 3 :  "RedeyeBuf"
9.429: 4 :  "Redeye"
9.429: 0 :  "JpegSrc"
9.429: 1 :  "Mip"
9.429: 2 :  "WorkingToMonitor"
9.466: "/opt/AfterShot2(64-bit)/supportfiles/tools//"
11.0: AfterShot2 Pro New key used. 20
11.2: Ready
11.108: QSslSocket: cannot resolve SSLv2_client_method
11.108: QSslSocket: cannot resolve SSLv2_server_method
11.246: QObject::connect: No such signal QAction::trigger(bool)
11.246: QObject::connect:  (receiver name: 'Directory View')
11.285: Initializing file system view...
11.286: File: s: 28
11.292: File system view initialized.
11.292: Container __CATALOG_ROOT__/assets
11.341: No custom slideshow settings found
12.199: MultiImageView::doCursor() Invalid cursor mode
12.203: Container __CATALOG_ROOT__/assets
12.204: viewmode: 1
15.587: Unlocking catalog:  "/home/froggy/.AfterShot/cache"
15.587: Unlocking catalog:  "/home/froggy/Pictures/AfterShot Catalogs/AfterShot Catalog 2014"
15.587: Early Cleanup
15.587: delete globals
15.587: delete mid globals
15.589: delete done globals
Syv
afx
System_Drive: N/A
Video Card: FirePro 4900
Re: Crashing 2.2
Post by afx »
Get rid of your plugins and install only those that have been recompiled for 2.2.
cheers
afx
pgman
System_Drive: N/A
Re: Crashing 2.2
Post by pgman »
I thought that these plugins are recompiled for 2.2/x64
I will check again
Syv
pgman
System_Drive: N/A
Re: Crashing 2.2
Post by pgman »
afx wrote:Get rid of your plugins and install only those that have been recompiled for 2.2.
I have checked and I only have the 64bit ASP 2.2 plugins
  • zone
  • grid
  • zchannel mixer
  • mix3
  • bez
Syv
afx
System_Drive: N/A
Re: Crashing 2.2
Post by afx »
Sorry, got mislead.
Interestingly enough the log looks just like a regular log, if I start and stop AS it terminates with the same messages.
(Mine only crashes when resulting from sleep).
cheers
afx
pgman
System_Drive: N/A
Re: Crashing 2.2
Post by pgman »
I did remove all the plugins and I've not had a crash in the last day and half
Syv
afx
System_Drive: N/A
Re: Crashing 2.2
Post by afx »
Now add them back one by one...
It might be a runtime library incompatibility between your system and the plugin developer system. I would expect an appropriate crash message though.
cheers
afx
