Hello,
I'm currently facing something that puzzles me : my photos are on an external drive so I can read them either on my Windows XP desktop or my Ubuntu 14.04 laptop.
Both are running 2.1.2.10, though 32 bits on XP and 64 on 14.04, and on both I use catalogging, but the paths for the catalog are different for the two computers.
That stated, I cropped a photo under XP and checked that the XMP file had been created within the folder containing the photo.
Then I connected the drive to the ubuntu laptop and checked the file still was there, and finally opened the photo... which displayed full sized (not cropped).
I altered it, but from the ubuntu machine this time, checked that the XMP had been updated, brought it back to the desktop and... the photo still appears as it first was cropped there !
And, after deleting the XMP file, both the Windows and the Ubuntu machine still display their own cropped one.
How can this be, since the XMP lies in the folder near the photo itself ?
Am I going nuts ? Is it a normal behaviour when using catalogging ?
J.-L.
XMPs from Windows to Ubuntu
Dutchmm
- System_Drive: N/A
- motherboard: Asus 97
- processor: Intel i7 4785T
- Video Card: Onboard Intel
- sound_card: Intel AC97
- Hard_Drive_Capacity: 2.5TB
- Monitor/Display Make & Model: Philips 28"
- Corel programs: ASP 3 Pro (and 2 and 1 before)
Re: XMPs from Windows to Ubuntu
Don't know for sure, but back in the mists of the 90s, there used to be a difference between UNIX and DOS in the codes for a line end in text files.
IIRC, for one it was CR LF, and for the other just LF. Again, from dusty memory 0x0a and 0x0d versus 0x0d.
There were programs in the utilities packages on both systems to make the necessary changes: ux2dos and dos2ux.
Now, far be it from me to suspect that anyone would have set up their compile systems with different and incompatible macros .....
afx
- System_Drive: N/A
- Video Card: FirePro 4900
The XMPs use UNIX line ends, no matter what OS. Just like AS uses / internally as a path separator
Try the whole thing in file system mode without the catalogs.
I regularly do a first culling and keywording run on Linux and then copy things over to a Windows box. The XMPs work just fine.
cheers
afx
cheers
afx
So, it might just be because of the catalog itself ?afx wrote:Try the whole thing in file system mode without the catalogs.
Yes, but in my case, I just bring the disk from a computer to another, the photos are common to both, only the cache and catalog are not common.afx wrote:I regularly do a first culling and keywording run on Linux and then copy things over to a Windows box. The XMPs work just fine.
Edit :
Yes, within file system mode it works perfectly.
So, this means that the catalogue as well must be common for both environments ?
2nd EDIT :
The catalog can't be common, due to file namming differences :
Windows says G:\Photos\NEF\
Ubuntu says : /media/jean-luc/1.8 To/Photos/NEF/
So even if I open under Ubuntu the catalog that XP created on G:\AfterShot\Catalogue\, it will never find /Catalogue/assets/G/Photos/NEF/ though it will display the thumbnails from /Catalogue.
Did I miss something ?
J.-L.
Hello,
I thought I could manage this using relative paths, and tried to follow the online help indications, but I didn't understand the way to achieve this at all.
I feel like the help lacks some informations.
I'm going to open a new topic for this.
J.-L.
J.-L.
