edwinn wrote:Hi Maureen, seems I've hit a wall with X7. Spent 6 hrs with it this morning. The gap that appears between the workspace and background in EDIT mode is becoming a nuisance.
Have you tried toggling between tabbed and non-tabbed view when that "crack" appears? I have seen that crack appear but only today read that this toggling is supposed to fix it. I haven't had the problem appear yet today but have created a button to toggle tabbed/untabbed and placed it beside the Window item on the menu bar. Will report back later to let you know if it works when the problem appears again.
edwinn wrote: The shadows around images, and the rendering of thumbnails in Organizer are a step backward IMHO.
That is definitely an issue when the window is larger than the image and, IMHO, is a bug that should be addressed. But as I usually work with the window set to Fit to Image it isn't something that affects me often.
edwinn wrote:Today I tried out Perfectly Clear X7U plugin for the first time and was shocked how crude it was. { screen-caps available }
My experience with Perfectly Clear is that when I have an image that is already in reasonable good shape but perhaps a bit underexposed and/or looking somewhat soft (I prefer sharp, fairly high contrast images) then Perfectly Clear seems to do an excellent job and can be tweaked besides. It doesn't seem to be able to do much, however, if an image has actual color cast, and it's denoise function seems to be much too aggressive in softening the whole image. In these situations the tweaking ability doesn't really help much. Keep in mind also that Perfectly Clear is not actually part of PSPX7 but is a plugin.
edwinn wrote:Was also looking forward to running Topaz plugins, but right off the bat, found the original image loaded into Topaz Clarify was displayed in different colors than in PSP X7 EDIT mode. It was `yellow´ in appearance or soft. So now I don't know what's real, and what isn't!
I have Topaz plugins and when I activate it I do not see any color cast whatsoever and the image that appears in the Topaz window looks exactly the same as the one in my PSP X7 workspace. Is it possible that the Topaz plugin you're using is pre-set to something that is causing that color cast? When you open the image in Topaz, try hitting the Reset button on the plugin and see if that fixes the problem.
