Ubuntu 14.04 : Full screen menus problem
Bugs & Suggestions
FalCT60
Post by FalCT60 »
Hello,
I didn't know where to post this...
Since I have problems with the latest version, I am still using the previous 2.1.2.10 x64, but this happened with previous ones too.
On my Ubuntu machine, if I display full screen (F11 key), then :
a) the menus are not active anymore, ie clicking on Fichier, ..., Aide will not drop down unless I first click on some menu within the working area (cataog, etc.)
b) when I try and click onto one of the three vertical left tabs (Bibliothèque, Système de fichiers, Sortie), then it lauches the application that is at the place on the (invisible at this moment) lauch bar at the left of the screen on the desktop.
Maybe do I forgot to do something ? An idea about what this could be ?
J.-Luc
uri2510
operating_system: Linux
motherboard: Gigabyte
processor: AMD Quadcore
ram: 8192
Video Card: Nvidia GT 9400
Hard_Drive_Capacity: 4 TB
Monitor/Display Make & Model: Medion
Re: Ubuntu 14.04 : Full screen menus problem
Post by uri2510 »
Which desktop do you use? (XFCE/Unity?)
Which graphic card? Did you change the driver for the graphic card?
Regards
Ulf
afx
System_Drive: N/A
Video Card: FirePro 4900
Post by afx »
Works on my Ubuntu LTS box, using XFCE.
cheers
afx
FalCT60
Post by FalCT60 »
@uri2510 : It is a Dell E4300 laptop with Mobile Intel GM45 Express Chipset.
I recently reintalled 14.04 from scratch to ensure all would be OK.
I display on a LG 32" TV at 1920x1080. The video cable has all its pins wired.
I didn't modify anything.
Rgds,
J.-L.
uri2510
ram: 8192
Post by uri2510 »
good to hear, try to find out, whether there is a intel graphics driver for your card. (Should be in Accessories - drivers). If there is one install it.
That would be your way to find out which driver you use:
Terminal:
inxi -G
tells you the name and version of your driver. The nouveau driver is not good for photoediting and has some problems with as2
Regards
Ulf
FalCT60
Post by FalCT60 »
Hello,
Your command displayed
Code: Select all
Graphics:  Card: Intel Mobile 4 Series Integrated Graphics Controller
           X.Org: 1.15.1 drivers: intel (unloaded: fbdev,vesa) Resolution: 1920x1080@60.0hz
           GLX Renderer: Mesa DRI Mobile Intel GM45 Express GLX Version: 2.1 Mesa 10.1.3
I'm currently browsing the net hoping I'll find something, but so far just went to dead-ends.
J.-L.
