A friend has video created using some sort of home transfer device that involved using a film projector and mirrors to project the film onto a ground glass screen for taping with a video camera.
Unfortunately the result is decidedly brighter in the center like a spot-light effect. The original film is lost to the sands of time, so this is what we have to work with.
I know that there is not going to be a lot of detail left,in the brightest part but is there some kind of inverse gradient glow effect available that could tamp-down the hot spot?
The area outside the bright glow is actually a bit dark so whatever evening-out of brightness might be needed those areas might be brightened to meet the center adjustment ideally.
Any such thing exist or could someone suggest a technique for salvaging the video? Thanks!
Looking for advice on correcting hot spot
asik1
- motherboard: H170M-E D3
- processor: i5-6600
- ram: 8gb
- Video Card: GTX1050-2GB
Re: Looking for advice on correcting hot spot
you will need to use 2 tracks of the video, where one will be applied a round gradient mask over the center.
and use color correction to adjust.
http://www.virtualdub.org/ has a hotspot plugin but I never tried it.
Panasonic X900m, VXF1
Presumably with some cropping as well asik1 - if you just put videos in two tracks then surely the one in the overlay track will then completely cover the other
OzoneTom
- motherboard: ASUS M5A97
- processor: AMD 6100
- Video Card: MSI GeForce GTX 750
- Hard_Drive_Capacity: 2.1 TB
- Monitor/Display Make & Model: Sharp HD Television
Excellent, these suggestions should get me progressing.
Thanks to you both!
Thanks to you both!
trailryder42
- motherboard: Gigabyte GA-890FXA-UD5
- processor: AMD Phenom II x4 965 3.7Ghz.
- Video Card: Nvidia GTX 560Ti
- sound_card: On Board Realtek ALC889
- Hard_Drive_Capacity: 256GB+3TB
- Monitor/Display Make & Model: Samsung Syncmaster 941BW
Doesn't the overlay track have an opacity setting?
