ASP 2.2.0.29 X64 not support Nikon D3300 yet.
Bugs & Suggestions
KOSKERS
operating_system: Linux
ram: 10Gb
Post by KOSKERS »
ASP can read the NEF file of D3300.
i saw ASP2 supported d3300 profile long time ago. but i want say ABLE TO OPEN AND SEE NOT equal OPEN IT CORRECTLY !!!
The WB never correct. it looks always green. Especially in dark environment.
My lens is Nikkor 18-55 VR2.
ASP2 can not recognize its lens information in EXIF. Hence Lens Correction is useless. when i choose to my lens in ASP manually,ASP can not correction my lens. Ugly.
Lightroom 6 can recognize my lens and RAW file perfectly. it can correct my lens too.
Even MACOSX 10.10 new application-- PHOTOS can open my NEF with the right WB.
please repair it ASAP.
Thx.
uri2510
motherboard: Gigabyte
processor: AMD Quadcore
ram: 8192
Video Card: Nvidia GT 9400
Hard_Drive_Capacity: 4 TB
Monitor/Display Make & Model: Medion
Re: ASP 2.2.0.29 X64 not support Nikon D3300 yet.
Post by uri2510 »
Lens correction data is read out of the exif-files. Errors occurre - as far as I know - because different manufacterers use the same modelnumber for their lenses. My tamron 2.8 70-200 is read as Nikon 2.8 70-200 mm. (Maybe the Nikon lens is a Tamron lens? Who knows nowadays? :) )
WB: Did you change the setting in AS2 and save it as default? White balance should be: "as taken" or something like that.
(I have a german version and there the standard is: "as taken" (wie fotografiert) ) And I don't have any problems with my 3 cameras (Nikon D300, Nikon D5200, and Sony alpha 6000)
regards Ulf
KOSKERS
ram: 10Gb
Post by KOSKERS »
Thx for replying.
When i import D90 and 5D3 RAW,the WB is correct.D3300 is incorrect. Using As Shot preset.
KOSKERS
ram: 10Gb
Post by KOSKERS »
uri2510 wrote:Lens correction data is read out of the exif-files. Errors occurre - as far as I know - because different manufacterers use the same modelnumber for their lenses. My tamron 2.8 70-200 is read as Nikon 2.8 70-200 mm. (Maybe the Nikon lens is a Tamron lens? Who knows nowadays? :) )
regards Ulf
BTW,for lens correction, u must choose your lens models maually if u want correct your photo.i have used D90 with 18-105mm ED. it can be correct the photo until u choose your lens models maually.
So if i have 1000 photos, i have to click it for 1000 tims???
afx
System_Drive: N/A
Video Card: FirePro 4900
Post by afx »
KOSKERS wrote:So if i have 1000 photos, i have to click it for 1000 tims???
Copy&Paste
Selective Copy&Paste
Copy Set
are all methods to make that easier.
cheers
afx
KOSKERS
ram: 10Gb
Post by KOSKERS »
Copy&Paste
Copy Set
cheers
afx
Thank you so much.
