[After ASP 2.2] What is your 3 most needed functions?
AlanT
- motherboard: HP Probook 6570b
- processor: Intel i5-3210M
- Video Card: HD4000
- Hard_Drive_Capacity: 256GB
- Monitor/Display Make & Model: HP Probook 6570b (1600x900)
Re: [After ASP 2.2] What is your 3 most needed functions?
I love AfterShot, and use it for 90% or more of my image adjustments. Unlike most of the other posters, I haven't downloaded and installed any plugins, and use the built-in features only.
ONE: As others have mentioned, a gradient tool would be a great addition. What good is a regional adjustment if there's a distinct line between it and the surrounding image?
TWO: For me, the next most important feature is accurate color management. When a bride spends a month picking out the perfect colors for the bridesmaid's dresses, she want those exact colors in the prints.
Yes, ASP can use ICC input profiles, but where are the tools to create a custom profile for your unique camera, lens, and lighting scenario? I just purchased the Datacolor SpyderCheckr target, and hope to use the HSL adjustment values produced by their software to jerry-rig a custom color profile in ASP. It would be great if there was a tool to use this and other standard color charts for accurate color management.
Also, related to the above, when I set a specific Kelvin temperature in my camera (Nikon D800), ASP doesn't report that number when importing the image. In fact, ASP, PaintShopPro, and Photo-Paint all report different and seemingly random numbers for this.
THREE: My third request would be to allow the various panes in the sidebars to be ordered to preference.
afx
- System_Drive: N/A
- Video Card: FirePro 4900
You can generate custom profiles for AS. Basically you use the mechanism described here:AlanT wrote:Yes, ASP can use ICC input profiles, but where are the tools to create a custom profile for your unique camera, lens, and lighting scenario? I just purchased the Datacolor SpyderCheckr target, and hope to use the HSL adjustment values produced by their software to jerry-rig a custom color profile in ASP. It would be great if there was a tool to use this and other standard color charts for accurate color management.
https://encrypted.pcode.nl/blog/2010/06 ... profiling/
(I've described it also in my book)
Color temperature numbers are not absolutes.Also, related to the above, when I set a specific Kelvin temperature in my camera (Nikon D800), ASP doesn't report that number when importing the image. In fact, ASP, PaintShopPro, and Photo-Paint all report different and seemingly random numbers for this.
The latest version of AS already supports this for the tools.THREE: My third request would be to allow the various panes in the sidebars to be ordered to preference.
But you can also use the good old customtools.ui hack described here: http://flightofthebibbles.blogspot.de/2 ... -tabs.html
also described in my book)
cheers
afx
macr237
- ram: 4GB
1. Grad Filter (Grad layer tool would be even better) and asGPS incorporated into ASP.
2. Unlimited number of actions in adjustment layers. Fed up of having a bad day with dust, only to find that I can't remove them all due to limitations and have to export to GIMP as Paintshop Pro is not supported in Linux.
3. A way that records all actions that you can go to and click the action that you have performed and toggle between off and on. Nothing worse that doing 10 separate actions and decide action number 2 is not required.
Also the Corel site needs a page that tells you when thing will be incorporated and next schedule release. For example Sony A7RII has been out a while and it hasn't been incorporated yet. When are we expecting it
dattanchu
- processor: i5 2500K
- ram: 16g
1. Grad Filter is critical in processing most images that has some sort of sky and horizon.
2. A before and after view without creating another version or turning on history and click back and forth. I just want a dual view of before and after.
3. A way to share/buy more presets.
Franz Dur
- motherboard: Asus H87-Plus
- processor: Intel
- ram: 16 GB
- Video Card: NVIDIA
- sound_card: Intel
- Hard_Drive_Capacity: 2.5 To + 3
- Monitor/Display Make & Model: NEC EA244WMi and Dell 1907FP
1) Gradient tool
2) Gradient tool
3) Better denoiser
I am still running 2.1.2.10 because of Gradfilter. I find the release notes confusing: will Gradfilter work in 2.2.2.70 (32 bits) ?
Francis
2) Gradient tool
3) Better denoiser
Francis
Arnfinn
- motherboard: ASUSTeK Computer INC. SABERTOOTH X58 Rev 1.xx
- processor: Intel Core i7 CPU 960 3.20GHz 3.20GHz
- ram: 12 GB
- Video Card: NVIDIA GeForce GTX 670
- sound_card: High Definition Audio Device [5x]
- Hard_Drive_Capacity: 12 TB
- Monitor/Display Make & Model: BenQ G2400W 24,0" + Acer X203H 19,9"
- Corel programs: ASP
Unfortunately there isn't any GradFilter or similiar tools running on ASP 2.2.X. The developer seems to have abandoned the plugin and Corel hasn't made one yet...Franz Dur wrote:I am still running 2.1.2.10 because of Gradfilter. I find the release notes confusing: will Gradfilter work in 2.2.2.70 (32 bits) ?
Long time AfterShot Pro & Bibble user...
http://creativewithlight.com/
Franz Dur
- processor: Intel
- ram: 16 GB
- sound_card: Intel
Thank you for the info, it is saddening.
Apart from the handling of raw from newer camera (which is not my problem) does 2.2 offer an improvement in image quality. I do not speak about ease of use, but basic image quality? I know I can use layers to +/- mimic Gradfilter but it is it is much more time consuming than a few clicks in the Grad plugin...
Francis
Francis
1. Skin softening brush similar to lightroom.
2. A gradient tool.
2. A gradient tool.
malepo
- System_Drive: N/A
- processor: Intel
- Video Card: Nvidia
- sound_card: Intel
- Hard_Drive_Capacity: 690GB
- Monitor/Display Make & Model: acer
- Corel programs: AS1, AS2, PSPX8
well me too
1. a gradient tool
2. a better masking brush - ideal like in Topas Remask
3. probably just for me but a functional lens db
1. a gradient tool
grcolts
- System_Drive: N/A
- processor: 2.5 ghz intel core i5
- ram: 8gb
- Video Card: Radeon HD
- sound_card: apple
- Hard_Drive_Capacity: 500gb
- Monitor/Display Make & Model: 21.5 Imac
Something else too...I would love to see a simplified printing mode. I have more trouble trying to print with ASP2 with boxes popping up, etc. and am never able to print through ASP2 and I end up having to print through Apple's Photos program. Fix and simplify the printing mode please!
Franz Dur
- processor: Intel
- ram: 16 GB
- sound_card: Intel
Like many others I asked for a gradient tool. I don't think it will ever come.
And I don't mind, I use now the gradient tool which comes in Color Efex Pro from the NIK suite. It works very well, at least as well as Gradfilter Pro, it integrates easily with ASP and it is free.
Francis
Francis
1. Stop chasing lens correction data and wasting cycles trying to keep ASP updated -- just make ASP compatible with http://lensfun.sourceforge.net/lenslist/ and call it a day. The data is already crowdsourced...
2. External filter support (like the many that Photoshop can point to, or the now-free Nik filters, for example).
3. Drag and drop right-panel plugins. If I want to change workflows a little and have a different 3 or 4 most-common-used plugins, it would be so much easier to drag them around instead of having to un-pin and re-pin them all over again in the order I want.
Kneops
- System_Drive: N/A
- motherboard: ASUS P8 Z68
- processor: Intel i7 2600
- Video Card: nVidia 450
- sound_card: onboard
- Hard_Drive_Capacity: 14 TB
- Monitor/Display Make & Model: Dell U2713H & Spider4
- Corel programs: ASP3
1 and 2, I definitely agree on. 3 would be a nice addition. I think Darktable has something like this, but it would make ASP even more faster and user friendly than it already is.
Captivatethem
- Corel programs: AfterShot Pro
I'm loving ASP so far, but the only thing that gets under my skin a little bit is not being able to reorder pinned items in the right panel, but I'm really digging the direction the interface is taking. I'm excited to see the next incarnation, cheers!
