Updating to 2.2 on Ubuntu but won't start with 'old' setting
Kneops
- System_Drive: N/A
- motherboard: ASUS P8 Z68
- processor: Intel i7 2600
- Video Card: nVidia 450
- sound_card: onboard
- Hard_Drive_Capacity: 14 TB
- Monitor/Display Make & Model: Dell U2713H & Spider4
- Corel programs: ASP3
I put this question in the wrong topic (the one with the release info), so I'm starting a new topic...
I installed the new version, but when I start it, it first asks me where to put the files. So I set the location to the folders I'm already using, but then ASP won't start.
When I choose a different folder then my already existing .AfterShotPro folder, namely .AfterShot folder, it will start, but then I loose all my settings and catalogs. When I set my catalog folder to the existing one, it creates a new empty one inside the old one.
I tried copying all of the contents of the old settingsfolder to the new folder, but then ASP again won't start.
macr237
- ram: 4GB
Re: Updating to 2.2 on Ubuntu but won't start with 'old' set
I was having the same issues. I think I may have solved it.Kneops wrote:I put this question in the wrong topic (the one with the release info), so I'm starting a new topic...
I have used the new catalogs and have tried File-> Open Catalog and then have found the 2014 catalog. It has now added it to the 2015 catalog. I am not sure if that is what you are trying to achieve.
macr237
- ram: 4GB
Hmm, maybe I haven't as it will no longer open.
Back to the drawing board.
macr237
- ram: 4GB
Anyone know where the config files would be hidden? I can no longer open ASP, I have removed completely, reinstalled and even have tried a full shut down, but I cannot get it to start.
afx
- System_Drive: N/A
- Video Card: FirePro 4900
Re-install rarely fixes anything...macr237 wrote:Anyone know where the config files would be hidden? I can no longer open ASP, I have removed completely, reinstalled and even have tried a full shut down, but I cannot get it to start.
Have a look at
Code: Select all
~/.config/Corel/AfterShot\ Pro\ v2.confCode: Select all
~/.AfterShot*cheers
afx
Kneops
- System_Drive: N/A
I opened the .config... file and the settings are the same as when using the option to choose the folders at startup:
.AfterShot
catalogfolder: home/jack/FotoArchiefASP
But as you can see, it only creates a subfolder in that folder and I still can't access my catalogs. I don't want them inside this newly created folder.
http://i.imgur.com/R7YIrsg.png
These are the current settings in the config file for ASP Pro 2: http://i.imgur.com/OowUthq.png
.AfterShot
baldrick777
- System_Drive: N/A
- processor: i3 Core
- ram: 4GB
- Hard_Drive_Capacity: 320gB +ext
- Monitor/Display Make & Model: Laptop + Samsung 22" ToC
It's a bug.
Seems the new version for Linux wasn't tested well enough before release. Best to delete all ASP config files and then completely remove ASP2.2. Once done, re-install v2.1 again. You should now be good to go. You'll also need to re-install any plugins you have previously. You shouldn't need to touch the catalogue folder.
Hopefully, the devs will be quick to release a patch to overcome this glaring oversight, then we can happily re-install 2.2.
Using Linux Mint 17.1 > gThumb Viewer > ASP2 (ProPhoto RGB) > Gimp 2.9 (dev). Specialising in landscapes, concerts and portraiture.
andreas
- System_Drive: X
- motherboard: Asus in Workstation and Dell XPS Notebook
- processor: i7-980 and i7-2720QM
- ram: 12GB - 8GB
- Video Card: ATI FireGL
- sound_card: on board
- Hard_Drive_Capacity: 4.5TB Rd10
- Monitor/Display Make & Model: Samsung Syncmaster 2343sw
please post the Log located in .Aftershot* folder.
Andreas
Andreas
Linux - not Windows
Kneops
- System_Drive: N/A
See attachment for the log file.
- Attachments
- AfterShotPro.log
- (123.26 KiB) Downloaded 329 times
andreas
- System_Drive: X
- ram: 12GB - 8GB
looks like these may be the problems:
Can you start on a folder with fresh NEFS without xmp files?
Andreas
Code: Select all
27.23: "BError: type = 1013, "decompressRawData cancelled" in file ../src/NefReader.cpp:2251"
57.442: Error - Unable to load setting created with a later version of Bibble.Andreas
Linux - not Windows
Kneops
- System_Drive: N/A
You mean when using the folder tab, not the catalog tab I assume.
I just did, but that doesn't give me the catalogs. But perhaps I don't quite understand what you mean.
Kneops
- System_Drive: N/A
I just tried something and now I have my catalogs back: I copied the rootdb file from the old folder to the new folder.
Nevertheless I think this can be considerd a bug. Updating to a new version should be basic and simple.
I'm facing the same issue : after installing the latest version, it asks for files and catalog location and, then
1- if I try to select the ones of the previous installation, it crashes
2- if I accept the ones that it suggests me, it works but
a- goodbye my settings
b- I have to re-enter my licence key.
Why can't ASP under Ubuntu correctly install simply retrieving the old parameters ?
Just one more thing : there are no NEFs nor XMPs on my disk.
EDIT :
OK, I found the reason : the version installed was rather old - 2.0.2.10 - and, at this time, it was AfterShotPro2, but since 2.1.2.10 it has become Aftershot2 !
Then, the versions are installed in folders called resp. AfterShotPro2 and AfterShot2, and they can be run independantly (but not together).
NB : 2.2.0.29 still refuses to run unless I remove the plugins (reading the release notes pointed me to this).
Hope they updtae the plugins so I can use ASP soon.
J.-Luc
EDIT :
J.-Luc
macr237
- ram: 4GB
Anyone know if this has been fixed yet?
I really want to install the update, but have been holding off.
macr237
- ram: 4GB
The only rootdb that came up on a search was in my home folder. Is this the rootdb that you are referring to?Kneops wrote:I just tried something and now I have my catalogs back: I copied the rootdb file from the old folder to the new folder.
