"Your Library is where you store one or more catalogs of photos. It is a key part of the asset management system. It lets you access the master files (original photos) as well as all the versions that you create."
I had assumed that this meant that when importing photos, that they were copied into the catalog. I inferred this because of how the catalog function is described. So, to test this, I used an SD card, imported images from it into a catalog, and exited the program. Then, I removed the SD card and restarted ASP2. When I tried to access the photos. I could see thumbnails, but not the images. I assume this is how it's supposed to work. That is, master files are not stored in the catalog. The catalog only stored thumbnails and data about image manipulations. If master images are removed from the computer for some reason (like pulling an SD card), then there's nothing you can do in terms of image manipulation.
Is this correct? ...or have I somehow misused ASP2.
Along a similar line, I have a dual boot configuration. I primarily use Linux (Linux Lite, an Ubuntu flavor) and occasionally boot to Windows 8. I have ASP2 available there, too. I thought I might be able to share the same catalog that was created under Linux. Apparently, this is not so. (The catalog is stored on a separate NTFS drive.) The problem is that the Linux based ASP2 catalog makes no sense to the Windows based ASP2. At best, I could just use the File System mode.
Is this correct? ...or have I, again, somehow misused ASP2?
See, newbie questions.
