Has anyone been able to get effective results with Advance=1 functions for mpeg2 renderings? I would like to set short GOPs like 4 or 6 frame intervals for better DV to DVD conversion. Whenever I change GOP settings in the Advanced options I see no difference in output. Artifacts are just as strong as ever.
System: Win XP Pro SP3
Videostudio Pro X2 Ultimate (no updates installed)
Added Advance=1 under [Viodriver] in C:\Documents and Settings\All Users\Application Data\Ulead Systems\Corel VideoStudio\12.0\uvs.ini
Advanced tab and Advanced Window appears in VS X2 for mpeg 2 options.
I set GOP to 3 P frames and 6 I frames and set it to render and burn DVD. I watch it through a DVD player and Full HD TV yet I see no difference with usual 3P and 12I settings.
Is there something I'm missing?
It seems as if we need to add another flag in the ini file to actually enable the Advance=1 options. Does anyone know?
Advance=1 not effective in VS Pro X2
PhilPreston3072
- motherboard: ASUSTek H97-PLUS
- processor: Intel I7-4790 3.60GHz
- Video Card: NVIDIA GeForce GTX 750 Ti
- Monitor/Display Make & Model: LG
- Corel programs: Videostudio 2019
Re: Advance=1 not effective in VS Pro X2
I don't understand how MPEG works, but a smaller GOP is not necessarily more optimized. I assume the defaults tend to work best for most video material.
MPEG is lossy compression and the amount of information lost is mostly related to bitrate
If you have space on the disc, try a higher bitrate. If you are running out of space on the disc and you are using LPCM audio, switching to Dolby (lossy audio compression) will save space, giving you more room to use a higher video bitrate.
[size=92][i]Head over heels,
No time to think.
It's like the whole world's
Out of... sync.[/i]
No time to think.
Out of... sync.[/i]
asik1
- motherboard: H170M-E D3
- processor: i5-6600
- ram: 8gb
- Video Card: GTX1050-2GB
If it's for DVD I think you can't just change the GOP. DVD video has a cretin format in order to be compatible.
even if you change gop it might be reencoded by the DVD module.
Panasonic X900m, VXF1
PhilPreston3072
Bitrate is already at 8000. Higher bitrates don't seem to make any difference. On Adobe Premiere the lowest I can set is I-frames to 8 and P-frames to 2 and there is a noticeable improvement, so I think if I could push the I frames down to 6 or 4 that would be so much better. The Advanced options do have those settings available but actually have no effect.DVDDoug wrote:I don't understand how MPEG works, but a smaller GOP is not necessarily more optimized. I assume the defaults tend to work best for most video material.
Still I would love to know if anyone got any effective improvement with any of the Advanced settings.
PhilPreston3072
Possibly.asik1 wrote:If it's for DVD I think you can't just change the GOP. DVD video has a cretin format in order to be compatible.
Still, I would like to hear from anyone who managed to get effective changes through the Advanced settings.
