How set "[jobname]" and how sort files?
Quacero
motherboard: ASUS M5A97 R2.0
processor: AMD FX-8350 Black Edition - 4.0 GHz
ram: 32 GB
Video Card: Sapphire VAPOR-X R9 290 Tri-X OC 4GB
sound_card: Realtek ALC887 8-Kanal High Definition Audio
Hard_Drive_Capacity: 256 GB
Monitor/Display Make & Model: ASUS PB278QR 27
Post by Quacero »
Hello,
I would like to import my photos from the SD memory card (or any folder). The files are saved as raw data and must be imported in the file system and in the library.
Furthermore, befor i import, I would like to place a [jobname] , so I can archive the images in another subfolder . But where I set the jobname?
Under which menu item is hidden and also i cant find, how i sort files.
My workflow should look with ASP2 as follows :
  • 01. images are viewed on the SD memory card , sorted out and get metadata , such as . [ jobname ]
  • 02. The images are imported into the library and the file system. ( the physical path looks something like this : X: \Images\YYYY\jobname\jobname_counter_yyyy - mm - dd.cr2) The library then means, for example . "Customers" and is available.
  • 03. The files are processed and for print, the Internet, or whatever.
Unfortunately I can not do this with ASP2 . :- (
Thank you for your help.
Sincerely yours
Quacero
afx
operating_system: Linux
System_Drive: N/A
Video Card: FirePro 4900
Re: How set "[jobname]" and how sort files?
Post by afx »
Quacero wrote:01. images are viewed on the SD memory card , sorted out and get metadata , such as . [ jobname ]
Not very efficient.
I suggest download first and then first culling and keywording.
Otherwise you work on a very slow medium and need to copy stuff later in a manual process.
Create a download or ingest batch queue.
Then right click on the mount point of the SD card and send the SD card to that queue. The queue will ask for a jobname and put the files in the right place.
Here is an example queue setup:
Create appropriate batch queues and assign them hotkeys. Note, a batch queue can output to multiple formats if needed.
cheers
afx
Quacero
ram: 32 GB
Post by Quacero »
Thanks for the useful tips. The workflow is much better than mine.
And I can do anything in a script. really good!
All steps can I make with only 4 buttons at very high speed.
I am now a ASP2 fan;-)
Sincerely yours
Quacero
