More missing content in VSx8
Mark Swanson
motherboard: Dell OJCTF8
processor: intel i7 6700
Video Card: AMD Radeon R7 350
Hard_Drive_Capacity: 1 tb
Post by Mark Swanson »
I just did my upgrade from VS7 to VS8. Now, I have a lot less content to work with, I don't understand it- mostly right now I am missing a lot of transitions. I have 40 transitions, and in VS7 I have many more- and some of the missing ones are ones I use a lot, such as "fade to black". It seems like I also am missing other things, for example I have five "color patterns", I had more before. I am not yet sure if I am missing other things I didn't notice as of yet.
I see there has been at least one discussion about this, and it quickly fell into talk about licenses and got a bit nasty right away. I don't think this is a matter of that, it seems like there are simply things missing from VS8.....any help here? I sure do want my transitions back!
  • Mark Swanson, guitarist and luthier
Mark Swanson
Re: More missing content in VSx8
Ok, I have uninstalled VS8, and re-installed it. I also re-installed the "content" and the "Bonus" files- but without first deleting these. Now, I have a lot more of the content, I have the Color patterns, the objects, the flash animations and all that...I seem to have all my effects BUT I hope they work right when I try to use them.
However, the transitions are still not there. When I pull down the drop-down menu for the different transitions, I have four items- "Favorites" (none showing), "all" (2 showing, Vitascene and Adorage and that is ALL), "Overlay transitions" (40 showing), and "ProDAD" (2 showing, Vitascene and Adorage). That's it, and I had a much longer list in VS7, and many more transitions. What is going on? How can I fix this?
Mark Swanson
Just thinking about it, I remember when I just installed VS8 for the very first time, and clicked to run it the first time it had a screen come up with a bunch of things loading in....and near the end of this VS crashed. I got the "Videostudio has stopped working" message....and then I ran it again and the program popped up but with the incomplete content.
Mark Swanson
Ok, it looks like I have success...I hope I don't run into any troubles as I use the program. Anyway, I had to uninstall and re-install everything three times, the third time everything seems to have loaded in properly! it's funny, I was never asked to register the software until this third time through! When I ran the program after the third install, it asked me to register and everything seems right. I don't think it was loading in properly. So, if you have been reading along, thanks for your time and I hope I am ok now!
Hi Mark
The X8 program is provided with two install files, the “Main” program and the “Contents” file.
These should be installed to provide full functions for the program, your libraries will / should be complete.
If you have purchased the Ultimate then an additional file is provided to install the extras, ProDad etc.
Finally a Bluray add-on is available at a small cost.
Given that the installation seemed to not completed correctly???, or did it?? you may have to re-install.
First can you re-set the program by renaming the folder “18.0” to “18.0 Old”
Running Video Studio will generate a new folder.
How………….
From the PC Start button-Search – insert %appdata%
That should find the Roaming folder, now locate the 18.0 folder, I think you will need to look in VideoStudio Pro X64 folder???
C:\Users\user name\AppData\Roaming\Ulead Systems\Corel VideoStudio Pro\18.0
Mark Swanson
Thanks. I still have a problem it seems. Now I have no Boris filter. I can't get it to install, I have tried re-installing it from the "bonus" installation files, still nothing. My control panel tells me the "Boris for videostudio X7" is installed....I left all of my VSX7 files intact before I tried to install VSX8....will that interfere? I have never had a problem with any Corel installations before this, dammit!
Hi Mark
I believe there was another user with a similar problem who uninstalled X7 then installed X8, that seemed to install ok.
I cannot think why X7 would interfere with X8 installation, certainly many of use install several versions without problems, indeed I have installed X8 many times during my testing for the forum.
So maybe give it a try, uninstall all programs, remove all personal details.
Then install X8
Resetting the library, Settings Library Manager should set the program to as installed.
Then you may have to re-name the 18.0 folder again to provide all content.
Those options work for me, although I have a good installation, I guess if your program has not installed correctly resetting things is not going to improve things.
Oh one thought, are both X7 and X8 64 bit programs :?:
Hi Mark
X7 and X8 use the same version of Boris Graffiti, (Graffiti6.vft) found in these folders
C:\Program Files\Corel\Corel VideoStudio Ultimate X8\vft_plug
C:\Program Files\Corel\Corel VideoStudio Ultimate X7\vft_plug
Do you have the Graffiti6.vft for both programs
When I was originally setting up X8, I too couldn't get Boris to show. The solution was to remove Boris which was already installed for X7. There is a separate entry for Boris in Control Panel > Programs and Features so there is no need to remove the whole of X7. Then I installed Boris from the X8 Ultimate Bonus file and it worked. However, I thought Corel, after talking to Boris, fixed this in a later update of X8 -- not a patch, just internal code within the versions they were selling.
The other thing you could try, if you have X7, is to simply copy the "Graffiti6.vft" file in X7's vft_plug sub-folder, and paste it in the equivalent folder in X8.
Please see http://www.videostudiopro.com/en/support/updates/ which contains a patch which should fix the Boris problem.
LeGrand
motherboard: Asus I 7 2600
processor: Intel 3.4 ghz
Video Card: NVidia GT740
sound_card: include inboard Asus
Hard_Drive_Capacity: 3 T 500SSD
Monitor/Display Make & Model: 2 Asus IPS HDMI
Corel programs: VS2019,X10,PSP2019,CDX7 WINDVD AfterShot
Post by LeGrand »
I have this problem and ask help to Corel Support, but what they say for response is ridiculous, why did they didn't know of this patch.
Corel knoe till march and we are in May and it seem that they didn't know for this patch .
I'm deceipt of that, cause it is the first problem i have with them and take a lot of time to answer me resolve my problem
I'm a good customer of Corel till more then 10 years
Sorry for my english cause i'm french talking
Ford GT and Mustang lovers
Hi LeGrand
And welcome to the forums
Are you saying that you have used the fix provided by Corel, Ken gave the url link above for Boris Graffiti
Can you say that the fix worked for you?
LeGrand
Post by LeGrand »
Yes it work , and really happy from your help , and today i just receive a note from the Corel suppport and they tell me to remove completely X8 with a little software they send me and reinstall on another Admin partition .
3 week waiting for this response ,
But now i'm happy to have join this community , your help is very appreciate
Thanks All , and share your idea or tricks : it help others like me
P.s. really don't know why the support didn't know that patch ??????
:D
