Hello,
The Triple Scoop Library in X8 includes 17 mp3 audio files.
When I try to drag one of them to the music track I get the message: "Corrupted video file(s) cannot be dropped", I can put this file in the music track by applying copy/paste.
I wonder if this is the way it should be done, as far as I can see (and hear), those files are not corrupted at all.
Any response will be appreciate.
Abraham
Triple Scoop Music in X8
- RobertOZ
- Hard_Drive_Capacity: 7 TB
Re: Triple Scoop Music in X8
No, that is not how it should be done, dragging into the track is the correct way, however I am now getting the same error message as you, not previously had an issue with Triple Scoop,there is definitely nothing wrong with the scores themselves,the all play perfectly, will need to test furtherzehavi wrote: I can put this file in the music track by applying copy/paste.
Very strange because I am now getting exactly the same error
but also very interestingly - I do not have to 'paste' - if I right click over the thumbnail in the library and choose 'copy' and then move the cursor down into the timeline over an audio track then the music block appears and a simple left click places it
- RobertOZ
Also Brian, if you right click a track in the library, then select "Insert To" you have the option of which track to insert to, which is not the way the PDF explains how to use Triple Scoop
zehavi
- processor: Intel[R] Core[TM] i7-8700 CPU 3.20 GHz
- Hard_Drive_Capacity: 465 GB
- Monitor/Display Make & Model: LG
Thank you Robert and Brian.
Good to know that this is not a problem in my VS.
asik1
- motherboard: H170M-E D3
- processor: i5-6600
- ram: 8gb
- Video Card: GTX1050-2GB
Same error here, but "Insert" a clip from library to a track works OK.
Triple scoop is more harm than good, the mp3's are 44.1 not 48K.
Panasonic X900m, VXF1
zehavi
So, we learn again that not everything is perfect.
